How to disassemble a lumina Throttle Body?
  • Ranger Larry
    • May 2009
    • 10
    Hi, I was wondering if someone could give me instructions on disassembling my 1996 lumina Throttle Body. I am going to replace with a 56MM with adapter. I can take it off and remove sensors i need to get everything else off.
    • 13498
    Adapter for what?
    http://60degreev6.com/forum/f115/diy...through-t32520
    You wouldn't need to worry about the dremel tool part because the 56mm plate fits as is.
    • geldartb
      The Situation
      • May 2004
      • 1994
      going from the 52mm to 56mm should require nothing but a gasket if it was bad.. its a direct swap.
      if you have to swap the linkage ben has a good guide that he posted.
      99 Grand Am GT
      1357 cam 227 233 .050 dur
      515 515 lift 112 lsa
      • Ranger Larry
        • May 2009
        • 10
        I was going to buy it from wot-tech but it looks like its missing the lever. Or does it come with everything and i just bolt on and attach linkage. I have never removed a throttle lever and was wondering if there is a sight that explains how.
          • 13498
          http://60degreev6.com/forum/showpost...85&postcount=2
          • Ranger Larry
            • May 2009
            • 10
            Thank You
            I just want to thank all of you who helped me figure it out you people are great and i can't wait to learn more of what is possible with my motor. Seeing all these nice cars makes me want to do more and learn more.
