Mazda Mishap
  • RednBlack
    Wood Hippie
    • Mar 2004
    • 2795
    Mazda Mishap
    Why idiots should not own wrenches.
    The story: My step-daughters boyfriend, replaced the water pump on his Mazda 626. In doing so, he needed to remove the balancer. The bolt was very tight! So, he held it solid with a prybar stuck in the sensor teeth. Then, with a mighty tug, that pesky bolt broke loose! As did several of the teeth. No problem. His neighbor was a welder. He made new teeth, he was very proud of his work!
    Uh,..there was a problem however, the car would not start, would not fire a lick.
    Picture is worth a thousand words...besides the crappy welding.
    • 13531
    But think of all the money he saved!
    • 1988GTU
      LB62LHObbqftmfw
      • Nov 2005
      • 2475
      Pure WIN!
      • RednBlack
        Wood Hippie
        • Mar 2004
        • 2795
        Can you spot the bastard tooth? There is a weld signature.
          a lot of them look shitty...
          did he also do this?
          • ikessky
            • 614
            Hey, we've changed a strut spring with a set of tow straps one time. It was one of the scariest things I've done!
