troubled stratus
  • joshsr
    • Jan 2010
    • 3
    troubled stratus
    Im havin problems with the transmission control module in my 95 dodge stratus with a v6 . i consistantly kicks itself into "limp mode" . . . it wont shift out of second. dealers and mechanics say there is a stedy problem with tcm's cause of the way they are manufactured. is ther anything i can do ?
    • 13531
    Sell it? Not sure why you joined our site for a dodge stratus issue.
      maybe the dodge motor is a chrysler 660?
      • Azrael
        Accelerating uphill in OD
        • Apr 2005
        • 763
        You need to find a way to read or get any codes out of the computer. If it's going into limp mode, it'll tell you why. If you can't do that then find a PCM from another good running stratus from the same year. If it still happens then it's a transmission issue (assuming the engine's fine).
        1995 Grand Am SE
          i THINK with chryslers, if you switch the key from off to on 5 times within 5 seconds, it will flash codes through the SES light...
          what the codes mean, i have no clue.
            If it's anything close to the tranny in my sisters Caravan the solenoid pack is external. I have a friend who had a Caravan as well, and one of the shift solenoids went out completely so he only had 1st and 2nd until changing that solenoid pack ($150 or $200, I forgot which).
