little random post
    got bored, started cross-referencing things...
    Earliest 3100 injectors, i think...
    slightly later revision, i think...
    supposedly, 17.7 lb/hr and 18.2 lb/hr...
    fuel injector rebuilding,fuel injector servicing, wholesale fuel injector supply to automotive service centers,and repair facilities around the nation
    looks to be a great cross-reference...
      anyone else find this odd?
      i've always been under the impression that a narrowband's rich/lean threshold(compared to 14.7:1) was between .45 and .55... not .35. this is from a narrowband simulator BTW.
        the liquid cooled harleys are 60* V-twins.
          The 2011 Mustang gets a 305 hp 60* v6 and a choice between 6 speed auto (same one used in the F150 Raptor) or a 6 speed manual. It seems Ford is copying Chevy, except I don't believe the Camaro has an option of a 6 speed transmission (auto or manual ).
          The 2011 Ford Mustang will receive a new all-aluminum 3.7 liter DOHC V6 engine. The new engine featuring twin independent variable camshaft timing, will churn out an impressive 305 horsepower and 280 lb-ft of torque. An automatic six speed transmission and a manual six speed transmission will be available as compared to the five speed transmissions available on the 2010 Mustang.
            camaro has both!
            good to see ford came to it's senses about the ancient 3.8/3.9 design...
              • 9190
              #21
              Camaro is a 312hp, and does in fact offer both a 6-spd manual and 6-spd automatic (for $995 more).
                Well, that's good news The Mustangs do look nice, but out of all of the "retro" cars, Dodge included, I think GM did the best job with the Camaro.
                  whoops, seems the mustangs went from the 3.8 to the 4.0, which was a 60* motor.
                  the 4.0 still only made 210HP though. LOL
                    And GM pulled that one out of their hat with 3.4 liters years ago I bet the 4.0 has more torque though. I'm willing to bet it's the same engine used in the Rangers, so it's a 2v engine, not a high reving screamer. I believe it's a SOHC, though.
                      indeed, supposedly makes ~245 lb-ft of torque or something close to it.
                      but it's hard to make torque without displacement or boost.
                        insanity?
                        oh, and they're functional!
                        so far, only on the A1 mask, though i may port them to $DF and $8F(and potentially others) as well, if there is anyone to test it for me.
                        and when i get home, main spark shall be the same.
                          • 13525
                          #27
                          Wow, does that take the place of the base VE table as well?
                            well, i more or less disabled the base VE table, since the calc'd VE from the 2D and 3D tables was added together and stored as an 8 bit variable, so there was no longer a reason to have it.
                            now i just need a motor that can spin to 8400
                            • Jonpro03
                              • 362
                              #29
                              Build a 3900 to do it
                                funny you should mention that... i may be using one of the +12V PWM outputs on a 1227727/16149396 to control the VVT solenoid actually, should i be able to get my hands on a 3900...
                                i just need to get some more info on the system first.
