New problem
  • stoneymonk
    • Mar 2009
    • 84
    New problem
    At around 70mph there is a slight vibration from the front end now could that be tie rods ball joints or maybe alignment issues.Also the car is a 95 lumina,news tires were put on last summer and one ball joint replaced.not sure if the alignment was rechecked after balljoint but the car has a slight pull to the right.
    i think you narrowed everything down once you said "pulls to the right"...
    before that, vibration could have been caused by lots of things, but if it pulls, then an alignment issue makes sense. it may not completely get rid of it, but it will be a good start.
      • 13531
      not engine related = moved to off topic. useless title as well....
      • RednBlack
        Wood Hippie
        • Mar 2004
        • 2795
        Hell, I'd keep driving it. Sounds safe enough....But then again, I drop ball joints in front of Autozone.
        Anyone know what those wires are? The ones sticking out of my tire?
          Those power your flux capacitor. Don't disconnect them or your kneuter valve may blow.
