Raise the car
  • RednBlack
    Wood Hippie
    • Mar 2004
    • 2795
    Raise the car
    I posted this, then deleted it and thought about it some more. I would like to know if there is a decent way to raise my 94 Cutlass Supreme about 3". Taller tires are not an option. There is a means to my madness!
  • v6h.o.
    • 1418
    hydraulics :P
    Colin
    • RednBlack
      Wood Hippie
      • Mar 2004
      • 2795
      Hydraulics are also not an option, unless I move to East LA!
        • 13531
        Hockey pucks. I dunno how exactly but I know they are in the canadian equation.
        • v6h.o.
          • 1418
          LMAO!
          Colin
          • RednBlack
            Wood Hippie
            • Mar 2004
            • 2795
            What I'm looking for is just a little more ground clearance. And possibly a little better weight transfer. And since I'm not drafting at Daytona, aerodynamics isn't an issue. But! I have an alterior motive! HeeHee! (Weebils just kill me!)
            • Lyle's GTP
              • Jan 2004
              • 1345
              How about Held Motorsports front and rear adjustable coilovers. That would be the best bet. I believe you get 3 inches in each direction with those. He said they are done, he's just testing.
              Lyle
              • RednBlack
                Wood Hippie
                • Mar 2004
                • 2795
                I was lookin at that. Tanx Lyle.
                • jmgtp
                  • 1219
                  No joke... new struts (KYB GR2s) raised the rear of my car about 2"
                  They did not alter ride height in the front though. I imagine different trim levels and years of W bodies had different front springs. Maybe there is a factory replacement option that offers greater ride height, same applies for the rear monoleaf.
                  1994 Corvette
                  LT1/ZF6
                  2006 Dodge Dakota 4x4
                  3.7/42RLE
                  • RednBlack
                    Wood Hippie
                    • Mar 2004
                    • 2795
                    Need 3". In front. Would love to keep the car level though. It's just an idea. Get me 3" and I will divulge my Madness!
                    • Mitch DOHC
                      • Jan 2004
                      • 261
                      i use to go muddin in my 91 4 door cutlass..... i rased the back alittle by lifting the car off of the ground and cutting a pice of 2X4 about s or so inches long not really sure on the exact length.. it has been a while... any way put the block under the rear momo leef in the middle between the spring and the center lift point.. bassicallt in the center lift point.... cut it to fit the exact space between the leef and the lift point...... it will lift a inch or to.... probably not the best thing for the spring but does work
                      1994 Cutlass Supreme Convertible 3.4 DOHC
                      1969 Oldsmobile 442
                      1997 Chevy Tahoe
                      http://members.cardomain.com/mperkins442
                      • Lyle's GTP
                        • Jan 2004
                        • 1345
                        Ok, let me get this straight, you have a W-body with a rear monoleaf suspension. You replaced the rear struts (shock absorbers), and it raised the car? Shock absorbers only dampen the oscillation of the springs, they have nothing to do with ride height. Unless your old struts we so fucked, they were seized in the down position. Then your suspension would have been "held" down by the struts. Therfore any old brand of struts would have had the same effect.
                        Lyle
                        • RednBlack
                          Wood Hippie
                          • Mar 2004
                          • 2795
                          That would really stress a monoleaf. Ass end is easy. Get rid of the mono and go coil overs. I want front end lift to equal what I can already do to the back. I thought about lowering the towers. Lots of cutting and welding. Not sure about alignment yet. We are almost ready to get to the Madness! Has to be an easier way.
                          • Mitch DOHC
                            • Jan 2004
                            • 261
                            i just thought of a possibable way to rase the front..... probably a bad idea.. i mean i am drunk right now but ....... on the front is it possibable to make a spacer to put between the top of the strut and the strut tower.......
                            1969 Oldsmobile 442
                            1997 Chevy Tahoe
                            • Anonymous
                              Tie me to your rear quarter panel and I will use all of my strength to pull up.
                              Now is this enough to divulge the madness?
