T.D.M. 1995 camaro, question??????
  • camarocurious95
    • Aug 2011
    • 6
    I read your guys previous post on the theft deterrent module, and my question is, after extensively looking over the wiring diagram, couldn't u bypass the whole module all together by going under the hood side of the ECM and running an ignition hot wire to fuel pump request ( drk grn/wht ) and to the fuel pump signal ( gray ). wouldn't that work, or could that possibly fry the ECM?
  • camarocurious95
    • Aug 2011
    • 6
    isn't there any one who has the knowledge t o answer my question? or am I on the wrong site/
    • CNCguy
      Bisong eater :P
      • 1017
      I don't know if 12vt would kill the ECM but it won't get it to start. You need to use a VATS bypass type device as the ECM needs to see a 50 htz (IIRC) signal to turn off the anti-theft. You can find VATS bypass boxes on Ebay.
      MinusOne - 3100 - 4T60E
      '79 MGB - LZ9 - T5
      http://www.tcemotorsports.com
        • 13522
        Measure the resistance on your key and then put that resistance in line with the 2 white wires in your steering column. Bypassed. I didn't have any luck with the module that is in line with the module itself, but the resistor worked perfect.
        If this isn't possible for whatever reason, then there may be a way to bypass the whole system but I do not know what it is.
        • walterdude
          Destroyer Of ALL THINGS!!
          • Feb 2006
          • 265
          Here is a link to a write up on the procedure Ben just outlined....
          Hope this helps,,,
          Tom...
          • camarocurious95
            • Aug 2011
            • 6
            Thanxs for all your input
            thanxs guys, for all your input. But, If you look at the wiring diagram, I think, all I have to do is run those wires from the ignition hot side of the fuse box, and I think that will bypass the T.D.M
              If all you want to do is trip the fuel pump relay, that would be fine, but... in the VATS systems, the ECM doesn't turn the injectors on until seeing that 50hz signal that CNCguy was talking about.
              • TechRod
                Destruction Worker
                • Feb 2009
                • 162
                Or if you have an ALDL cable you can talk to madtuner and have him turn it off in the tune like I did and give that VATS the boot.
                "It's your car. Do with it what you wish, but as you enter this unknown world you will need to invent the wheel all over again. For the adventurous and those that are backyard mechanics who have nothing but time you might like this. Most have plenty of frustrating moments and the process usually takes significantly longer then what anyone could imagine. The end result of this conversion is completely up to you." - Jon McCullough of BMCautos.com
                • camarocurious95
                  • Aug 2011
                  • 6
                  I see it not only shuts the fuel pump down it also shuts down the injectors and everything...ahhh... I didn't know that.. well... thanxs all u guys for your input its much appreciated. when I get the sucker running I'll let u all know, thanxs again
                  • TechRod
                    Destruction Worker
                    • Feb 2009
                    • 162
                    I've got a VATS bypass that I'm no longer using (turned off in tune), $20 + shipping?
