FFP Chip+Emissions
  • montessgtp
    • 115
    its a few causing my high NOx one was the wrong plug..2 was my EGR is turned off on your chip 3... i have a miss fire... all 3 bein reason for bad NOx reading...
    1996 Dodge Ram 5.9/4x4
    1992 Grand Prix GTP LQ1/4t60-E
    1986 Monte Carlo SS 355-3-71SC /200r4
    • JasonZ34
      • 116
      yeah i want to move out of emissions testing sooo bad
      • Juglenaut
        • 1130
        SD doesn't give a crap about your car emissons. However if you have a cat cat and a cop gives you a ticket then guess what you get a free emissions check and the listing is Fed that you have to live up to and if you don't go to the emission testing site you goto jail for upto 30. They also impound your car and also may charge you a huge amount to have it fixed before you can even get it back.
        Thankfully most cops are out for the big tickets.
        I am back
        Mechanical/Service Technican
        • JasonZ34
          • 116
          Okay I added another one from last year which is very interesting. If it stops working again let me know. Maybe someone can host them for me for a little while.
          Any Ideas what would cause the NOx numbers to change so much from last year?
          edit: could it be the stat? 15* cooler
          • quantum110
            • 175
            NOx is controlled by the EGR.
            67 Olds Cutlass 2bbl 330 w/ 2 speed Jetaway
            • ProjectMM
              • Mar 2004
              • 170
              #21
              the CAT also will lower NOx numbers, but it's really reduced by the EGR valve!
              2002 Pontiac GrandAm GT1
              3400 v6
              TOG headers
              RSM 62MM T-body
              FFP underdrive pulley
              GRANATELLI MAF
              Ported upper intake
              MSD DIS 4 ignition box
              MSD Wires and coils (pending)
              Venom high flow fuel pump (pending)
