FFP Chip+Emissions
  • JasonZ34
    • 116
    FFP Chip+Emissions
    Got chip from FFP designed for 180* stat, and EGR valve OFF. I decided I would get my car tested with it off and see what it does. And oh man, how I failed. The numbers are hard to see but they're there.
    First Run FFP chip
    Numbers
    Test 25/25
    ----------Tested/Allowed
    HC ppm 15/114
    CO % .01/.63
    NOx ppm 1057/796
    RPM 1688/2500
    CO+CO% 14.9/ 8min
    Test 50/15
    HC ppm 16/117
    CO % .01/.65
    NOx ppm 1511/879
    RPM 1786/2500
    CO+CO% 14.9/ 6min
    Second Run, immediately following the first I backed up installed the stock chip and went back at it. I may have failed because I didn't give the engine any learn time and the Cat had time too cool.
    Test 25/25
    HC ppm 52/114
    CO % .04/.63
    NOx ppm 432/796
    RPM 1687/2500
    CO+CO% 15/ 8min
    Test 50/15
    HC ppm 19/117
    CO % .01/.65
    NOx ppm 976/879
    RPM 1804/2500
    CO+CO% 15/ 6min
    Third run stocker still in after 45 mins or driving.
    Now this is interesting, same car, one year ealier, the only difference is I had stock chip and stat in. So really the only difference is stock stat. Don't know if the time the stocker was in would have changed anything.
    What would cause that change?
    • 13533
    Interesting. I cant read the top numbers, so I assume it passed with the chip though in the end? Looks like our lovely EGR isn't too necessary.
    • JasonZ34
      • 116
      Originally posted by SappySE107
      Interesting. I cant read the top numbers...
      Edited it to include numbers
        • 13533
        ah ok, so it did fail for the NOx, which is EGR.
        • JasonZ34
          • 116
          Yeah but like i said i would imagine my emissions tests are very hard. Maybe next to CA only.
          • RebelGT
            • 642
            mine passed my egr was off to, and thats NJ, one of the strictest states in the union ::shrugs::
            26+6=1
            • kanchou
              • Mar 2004
              • 96
              ca, then ma, then nj i think
              • patgizz
                The Plaid Bandit
                • 1071
                my 3400 w/o egr just needs to pass for a stock 3.1 thats 7 years older, hopefully i can do it. bad thing is i dont have my 3.1 chip anymore
                • JasonZ34
                  • 116
                  then why would i have failed? what where your NOx numbers?
                  • Anonymous
                    Mine passed to, once I handed the Jiffy Lube guy a 20....
                      • 13533
                      no one cares aaron.
                      • Anonymous
                        I was just makign the point that mine did not pass with the chip, but I do nt think that it is directly related to the chip
                        • montessgtp
                          • 115
                          I failed emission badly NOx is up over 1500... =( i hate NJ
                          1996 Dodge Ram 5.9/4x4
                          1992 Grand Prix GTP LQ1/4t60-E
                          1986 Monte Carlo SS 355-3-71SC /200r4
                            I went by a tree, and the leaves didn't turn brown and fall off, so I passed emissions around here...
                              • 13533
                              ROFL! yeah, thats indiana emissions testing for you:P Running too hot of a plug could be causing the issues though for NOx right? I need to find out what plugs would work in mine but be 1 stage colder just to try out.
