3.4 dohc swap to a volvo 740!
  • GrandPrixGTP2000
    • May 2013
    • 5
    Hey guys!
    Well my friend has a 1990 Volvo 740 sedan, he had blown the engine, any way we were thinking about swapping my 3.4 out of my old gp I wrecked and putting it in his Volvo. I had some questions (if this is even possible). First would his tranny in his Volvo work on it? I know that I will need the computer, wiring and all of that. The biggest thing on this is if the trans will work or not? Any help would be appreciated! Thanks guys!
    gulf blue 1999 Grand prix GTP coupe
    • 13522
    adapt the bellhousing if necessary, sure. Worth it? absolutely not.
      Those are RWD right?
      If so I have a 700R4 that will bolt right up to your 3.4 DOHC, all you'll need to do is grab a torque converter for it. Has a modified TransGO shift kit from Probuilt Auto and a Corvette Servo already installed.
      Could be a fun project if there is enough engine bay room for that big DOHC.
      • TurboGTU
        • 453
        The ZF4hp22 automatic in the volvo is a POS. Save for the 700r4 or 4l60 that will bolt up. You also need a Yoke from the doner trans to mate with the new drive shaft you need to make.
        • Nas Escobar
          • Jun 2013
          • 10
          Hmmm this is a first... usually people run away from the LQ1 unless you have a Fiero.
          Anyways, the best way to do this would be to swap everything GM power component into the Volvo. An RWD GM trans (because the 740 was RWD), a bellhousing that will bolt the 3.4 to the new trans, computer, and all wiring. It would get tough with the gauge cluster and you would probably need your own motor/trans mounts, but other than that I don't see why you shouldn't do it. As others have said, the 700R4 or a 4L60 would be a good choice. Don't get the 4L60E since that relies on the PCM/ECU to work. The 700R4 would probably be the easiest to do. You would probably have to gear the rear end of that Volvo to accept the 700R4 though. I don't think that would be plug in a new yoke and drive.
          As always post pics or it didn't happen!
            The stock ECM from a DOHC car could run it just fine. The auto that came with most DOHC was a 4T60E.
            • Nas Escobar
              • Jun 2013
              • 10
              If I'm not mistaken that was the only one that was available. Wouldn't the ECM make the trans shift funny though? I would think that the 4T60E and the 4L60E are geared very differently.
                They may be geared differently, but that could be taken care of in the ECM easy enough with a chip burner.
                  4L60E has a pressure control solenoid, 4T60E doesn't. while the code COULD be adapted to control it, kind of a pain to do.
                  • nonhog
                    • Feb 2012
                    • 22
                    Plenty of Volvo guys adapting GM auto's to the Volvo plant. That tells you something right there. GM trans will fit with minor massage work. (small sledge)
                    I have a 4RW70 (Ford) in a Volvo. That's as big or bigger than a 700R4.
                      i seem to remember volvos of that vintage having overly strong manual transmissions? am i remembering this wrong?
