2.8L VVT Turbo
    • 9191
    2.8L VVT Turbo
    Just a quick preview of the new 2.8L VVT Turbo, courtesy of GM Powertrain...
    The 2.8L V-6 Turbo is a new variant of GM's advanced global V-6 engine family, which features all aluminum construction, dual overhead cams, variable valve timing and a host of additional technologies and refinements.
    First to be introduced in the 2006 model year Saab 9-3, the 2.8L V-6 Turbo will produce 250 hp (184 kw) of power and 258 lb.-ft. (350 NM) of torque.
    The new engine will be produced at Holden's Port Melbourne engine plant, where a 3.6L version of the global V-6 is currently produced.
    Stephens said turbo charging is just one of many ways GM is increasing engine performance and efficiency. Another method is displacement on demand, which improves engine efficiency by seamlessly deactivating half the engine cylinders when they're not needed.
    • 13533
    Yes, ill take some logs for exhaust manifolds. I thought they did away with those after gen 2! Other than that, some high res pics would be nice
    Im waiting for the saab owners to show up once this is released.
    • quantum110
      • 175
      No damnit they dumbed it down...it was originally suppose to be 280hp. This better be the Aero version w/ a 280hp Viggen version coming out later.
      67 Olds Cutlass 2bbl 330 w/ 2 speed Jetaway
        • 9191
        Ok, here is some more info on this new engine. The pics should now be in the gallery, so go there to check out the Hi-Res versions of them...
