Its all there
  • geoffinbc
    Iron Head Enthusiast
    • 5831
    Its all there
    Every pushrod specification is up. Infact every 60* V6 engine specification is up. 3.6LVVT, 2.8L VVT and 3500 included.
    PLEASE, PLEASE double check my work. There is alot of freaking numbers and I had to go through alot of papers. So make sure I didn't mix anything up. This only goes for the 1996 and older motors. Everything newer I just pulled off of GM's site.
    Enjoy!
  • robby1870
    Squaddoosh
    • 584
    RE: Its all there
    I just looked through some of it. Very nice and thorough. Good job!
    Robby Whitesell
    2006 Pontiac G6 GT
    1985 Toyota Pickup DLX
    • dohcfiend
      King Chalupa
      • Jan 2004
      • 2351
      RE: Its all there
      i noticed the 3.4 dohc section could be a little better. i personally don't know where to get the info but duration and lobe seperation would be nice. as well as the specs for the 3 generations of it. also i believe the cid to bo incorrect. 240? that is bigger than a 3.8(231)? i think you might have meant 204 no biggie.but on the rest good job. u da man.
      • geoffinbc
        • 5831
        I could only get the 1996 DOHC specifications. GM never lists lobe seperation or duration. The only reason the list the lift of a cam is so during a service period you can measure and see if it is worn. If you get me, Brad or Ben the information we can always add it.
        • Anonymous
          The 3.4L DOHC is 207 cid.
          • RednBlack
            Wood Hippie
            • Mar 2004
            • 2795
            You totally missed the color spectrum. What color should I paint my engine to make it go fast? :P Good job...
            • RacerX11
              • 1060
              No, it isn't. It is 204 cid. Just like the puchrod 3.4L. 204.5 cid, if you want to get exact. Go run the numbers....you will see.
              Marty
              '99 Z-28 - Weekend Driver
              '84 X-11 - Time and Money Pit
              Quote of the week:
              • PlatinumZ34
                • 232
                ya i've seen that before too, i've seen numbers between 204 and 209, maybe 207 is just the average :P. But in my serial thing under the hood it says 207 and thats what its known as... Just as the 427's aren't really 427ci...
                2001 Mustang GT
                1991 5spd Lumina Z34 - Dead
                1947 4spd International - Dead... Reincarnation pending.. getting close now .
                • RacerX11
                  • 1060
                  That's becase everyone assumes it is a 3.4L (3400cc), when it only displaces 3350cc. 3400cc = 207 cid, but 3350cc = 204 cid.
                  Quote of the week:
                  • Anonymous
                    My top end gasket set has on the cover "Top End gasket kit for 1991-1993 3.4L 207ci DOHC V6," so I was going off that, but I do realize that the assumption is that it is 3400cc.
                    • PlatinumZ34
                      • 232
                      is it not 3375cc or something like that??? But either way right now he has it as 240ci. And the compression is only 9.5:1 in the newer engines and manuals, 91-94? autos were 9.25:1...
                      EDIT***woops sorry i didn't see your post RacerX11
                      2001 Mustang GT
                      • Anonymous
                        91-93 manual-9.5:1
                        91-95 auto-9.25
                        96-97-9.7
                        • geoffinbc
                          • 5831
                          I fixed the 240 thing it is now 204. I will leave everything as GM specs it out.
                            • 13531
                            I lost my cam specs for the 91-95 though now with those 96 specs up.
