3100+3800 in a Cutlass!
  • 1QUICKHATCH
    • 387
    has any one seen this yet?
    should have used two 3100 (or 3400's) to help keep the weight down!
    14.96@91.47 in the 1/4
    9.63@74.36 in the 1/8th
    • 13531
    RE: 3100+3800 in a Cutlass!
    Yup, seen that. May have posted here as well though I know he is on a few other boards. He is going with twin 3800s eventually.
    • Guest
      Ok, I'd like to see pics.....
      But from what I read there, adding a second engine to run only a 13.8?
      Should have spent way less time, probably less money and turbocharged the 3100, would run the same or quicker.
      • Manitcor
        • 573
        he cam to the yearly MyMonte meet, regaurdless of the engines used I was quite impressed with the setup myself, alot of work and not to shabby, the entire car including roll cage came in at $2000 granted the guy is an ASE master tech and his co-hort is a pretty good wrench himself.
        Hes prob one of the smartest rednecks ive met
        heres some pics from that meet:
        http://www.mymonte.com/gallery/thumb...album=1&page=4
        front
        rear
        cabin
        Theres more at the hyper link and a bunch of videos on page one I think they got one of his runs.
        1995 Monte Carlo LS
        3400 SFI 60v6
        • blackbombshell95
          Kaiō-ken X 10
          • Jun 2004
          • 1386
          he was racing with his window down
          02 GTP - 90* > Failboat
          www.blackbombshell95.com
          • spacecadetz26
            • Nov 2004
            • 119
            thats because it was 100 degrees out and 100% humidity.
            Stephanie
            92 GTZ ~SupermoddedW41GTZ~
            • Manitcor
              • 573
              yeah it was a horribly hot day and everyone was running like ass, that was thier first time at the track as well, i would say the car does better than that. I think for them its not so much the speed as the uniqueness of the project.
              1995 Monte Carlo LS
              3400 SFI 60v6
              • Kyles93Z34
                • Dec 2004
                • 347
                Just think if that had twin 3.4DOHC engines. Did they just put the front chassis from the other olds on the rear of that one and then cover it up with the body? That is still freakin awesome. It has got to sound weird.
                1992 Lumina Z34
                5 Speed
                Autozone civic intake
                Ultra White lights
                FFP Dogbone mount
                125k miles
                2.5 inch Magnaflow catback from Magnaflow cat
                60degreeV6.com Custom Chip
                • Manitcor
                  • 573
                  its a custom rear cradle IIRC. both engines can start and run independantly of the other. and you can drive with either or both. 1 fuel cell, 1 massive fuel pump speced for pro-street applications.
                  1995 Monte Carlo LS
                  3400 SFI 60v6
