Custom/Billet mounts and bushings and such
    • 13534
    Im not sure what to focus on first but I have been told now that the same company that makes the throttlebodies can also make molds for bushings and motor mounts and whatever else. I was thinking about the W body lateral arms and bushings to swap out the rubber pieces in the GMPP trailing arms. I know the 3x00 swap into a J body needs a custom mount as well so if anyone has one or the dimensions needed, I can have those made. Mostly its the demand for these parts that will determine what gets made and what doesn't, so if you have any ideas, im open to suggestions.
    Probably wont work on any underdrive pullies and dogbones as FFP has those covered, unless we can make an UDP with the torsion dampener ring in there. Liability/warranty issues though may make that not happen but I wanna check into it anyway since I know some people won't replace theirs without that piece on the pulley.
  • Lyle's GTP
    • Jan 2004
    • 1345
    If you can make any part for our cars that is better than factory, I'm in.
    Unless the price is completely outrageous, I will buy it.
    Lyle
    • onefastV6
      • Sep 2005
      • 880
      I am in, it just depends on what you can make for a grand am.
      2000 Grand Am GT
      2011 Chevy Impala
      • EspanolaGuitarista
        Visionary
        • Feb 2004
        • 254
        I thought about that too...
        What about solid bushings for the trailing arms and lower control arms? The solids for the front would help with torque steer.
        • Manitcor
          • 573
          Id say if you can make a UD pulley that accepts the stock dampner that would be a big step in the right direction as far as pullies go.
          1995 Monte Carlo LS
          3400 SFI 60v6
          • dohcfiend
            King Chalupa
            • Jan 2004
            • 2351
            how about poly mounts for a lq1 car?
              • 13534
              The lowers? I can pull them off this motor I have and see what can be done about them.
              • brad
                • 39
                How about more poly trans and motor mounts for the J-body cars? I keep on tearing my tranny mount and I refuse to pay so much for the JBP one when they are so bad at getting their products shipped.
                Brad
                • El_Diablo
                  STFUniversity
                  • 917
                  n-bodys could use some help as far as mounts go.....
                  • Mr.H.O
                    • Feb 2006
                    • 39
                    Trans mounts for 5 speed 92-95 Grand Ams would be a plus,id be in if the price wasnt to bad!
