AMSOIL Products
  • RednBlack
    Wood Hippie
    • Mar 2004
    • 2795
    AMSOIL Products
    Who uses it? I'm not a sales person, yet. But, they claim to have the best synthetics made. The Performance Tranny fluid sounds good.
    Gimme some input. I'm about ready to dump some money into it.
    • 13531
    Ive used it before on my 3.1 but since my oil was always dirty looking after 500 miles (worn rings, excessive blowby), I stopped using it. I just put some in my DOHC motor a couple months ago and it will be the last time I use it since my motor sucks it up into my new PCV filter along with condensation. So I can't recycle the oil that gets sucked up
    Neither of these really reflect their product...just my lack of ability to make full use of the long life span it offers compared to the small amount of price difference between it and mobil 1. Good thing I got a case...I gotta add a quart every 500 miles or sooner.
    Ive used it in a friends car but that was an econobox. The oil looked clean after 3k miles...then I moved from phoenix:P see, im no help at all!
    • blackbombshell95
      Kaiō-ken X 10
      • Jun 2004
      • 1386
      You're really no help Ben. lol Emo
      A local 98 GTP owner has been using amsoil since he bought his car NEW in 1998. He said that it dropped his normal temp down 10 degrees vs ... hmmm, either royal purple or mobil 1 oil. I forget which oil he was comparing to.
      02 GTP - 90* > Failboat
      www.blackbombshell95.com
        • 13531
        His oil temps or coolant temps? It hasn't done shit for my coolant temps but I wasn't expecting it to anyway. My car get a little better throttle response...but I think thats my PCV in line filter doing its job:P
        • Manitcor
          • 573
          Over regular oil Ive noticed slightly lower coolant temps when its fresh.
          As far as how long it lasts. I ran 20k with my 3400 on one oil change. Just change the filter and top it up every 5k. I had oil analysis done at each interval. At 20k I still could have gone longer accornding to the tests.
          I use it religiously in my engine typically to 7500-12000 miles per change with a filter change out somewhere in the middle. Been doing it for about 2 years now.
          I ponied up the dough for a distrubuiter discont ($20 for a year). The discounts are worth it and they have some nice stuff other than just oil. Stay away from their trans fluid though. Its not certified.
          1995 Monte Carlo LS
          3400 SFI 60v6
          • geoffinbc
            Iron Head Enthusiast
            • 5831
            I'm running my entire drivetrain on synthetics. I get on average about 60Km more on a tank of fuel than I used to. None are AMSoil products. The engine and trans is Mobil1 and the Diff is Penzoil.
            The gas savings alone is worth the extra money. The fact that I extend my change interval to double the distance makes it even more worth the cash
            • GTP_MuNkY
              • Jan 2006
              • 113
              Probably Royal Purple...I think it may be the cause of my engine running hotter than when I got it. When it was fresh I know I noticed an improvement in the car...and I haven't really noticed a loss since then. (no, I don't have numbers to back this up, I felt it in the seat of my pants) But, again the car runs hotter, mostly in the first 20 minutes of the car being on...like say I accelerate hard too soon, the temp will sky rocket momentarily.
              Jamie
              1995 Pontiac Grand Prix GTP
              3.4L DOHC
              My Cardomain Page UPDATED MARCH 10, 2006
              • sharkey
                • Jun 2004
                • 2061
                i just switched over to royal purple about 400km ago. so far, it doesnt burn it, so i think itll be ok in my car. i would run amsoil, but its still about $3/l cheaper for royal purple. ill see how it goes with it.
                • RednBlack
                  Wood Hippie
                  • Mar 2004
                  • 2795
                  The one thing I don't understand is this. Why can I use Type F fluid instead of Dexron, (which I have done for years), but AMSOIL Racing Tranny Fluid is not compatible with Dexron? This is from their website.
                  http://www.amsoil.com/storefront/art.aspx
                  Note: AMSOIL Synthetic Super Shift® Racing Transmission Fluid is not recommended as a replacement for Ford Mercon, GM Dexron or Chrysler ATF+ type fluids in passenger vehicle and truck transmissions as it may cause erratic shift patterns, chattering or noise. AMSOIL is not responsible for transmission performance inconsistent with those specifications listed and where transmissions have been modified from the original manufacturer’s design.
                  And the tranny fluid is what I really wanted.
                  • sharkey
                    • Jun 2004
                    • 2061
                    the amsoil appears to be a race tranny fluid, were you want hard shifts at WOT, every time. the fluid isnt designed with normal driving were part throttle shifts are the reality. it doesnt have the friction modifiers in it that will work well on the street. its kinda hard to explain.-
                    • RednBlack
                      Wood Hippie
                      • Mar 2004
                      • 2795
                      So it is compatible? Just not for Grandmas' car.
                      • Syn
                        The Master Piece
                        • Oct 2005
                        • 599
                        i run the amsoil syn atf in my saturn and it shifts amazing and everything. haven't had any problems and i have put some good power threw it being boosted,
                        so it gets my vote
                        • Manitcor
                          • 573
                          AMSOil ATF almost meets all the specs to be DexronIII compatible but not quite. I wouldnt use it personally, I had shifting problems after switching to it in regular driving situations but it was great on WOT runs.
                          For trans fluid I would reccomend using GMs new DexronVI its completly comptible with DexronIII however is far superior in longevitiy and performance. Currently its only availble from GMPD and for your dealer.
                          Get the premium .com domain you deserve. Seamless and professional transactions. Payment plans available.
                          1995 Monte Carlo LS
                          3400 SFI 60v6
