Rear Struts
  • stantmann
    • 81
    Rear Struts
    Hi All,
    I need to replace my rear struts on my 93 3.4 Cuttlass convertible. I have yet to break out the book on it, but was wondering if any of you have any tips before I get started. Do I need to be aware of any tough situations I will run into. Since I am already in there, anything else that I should replace?
    Stan
    1994 White Cutlass Supreme Convertible 3.4 DOHC
    Add Ons: Overhead Display, Digital Dash, Trip Computer
    • 13531
    its a ton of fun...can't think of any tips other than breaker bar and air tools.
    • Anonymous
      24mm deep impact socket is the only tool I needed that I didn't have. Might wanna look into that. Its a pretty easy job altogether.
      • Rhedalert
        Dr. Feelgood
        • 1574
        Look into getting the rear struts that do NOT have the elongated lower knuckle bolt hole that allows movement/alignment. New Monroes have them this way. Just install it and it stays in one place and you won't need to guestimate a position or get an alignment (As long as you dont have accident damage)
        Also now is a good time to get new upper mounts if yours have any rust, also get the rear jounce bumper/shield kit to prolong the strut's useful life.
        Brian
        3400 SFI V6, 4T60e
        • Anonymous
          KYB GR2s have the elongated hole. It makes for a fun trial-and-error process.
          • stantmann
            • 81
            I'll be doing that over the holiday weekend. I haven't bought any of it yet. Are you saying get the Monroe Struts or not to? Any name brand suggestions for struts, upper mounts, bushings, etc?
            Thanks,
            Dennis
            Stan
            • Rhedalert
              Dr. Feelgood
              • 1574
              New Monroes are easier to install cause they don't have the elongated hole, but even if it did, it isnt much harder
              Brian
              3400 SFI V6, 4T60e
