My First Track Experience
  • Azrael
    Accelerating uphill in OD
    • Apr 2005
    • 763
    If the trans fluid was as bad as Kyle says it was, there's a chance it'll gain marginally better times. Good fluid equals efficient shifting and less power lost to friction.
    1995 Grand Am SE
    • blackbombshell95
      Kaiō-ken X 10
      • Jun 2004
      • 1386
      in other words, nothing in the 1/4
      02 GTP - 90* > Failboat
      www.blackbombshell95.com
        • 13533
        No, you can run type f, and a better cooler and im sure the better shifts will equal better times. Im not sure how much bad fluid will cause it to slow down though either.
        • Kyles93Z34
          • Dec 2004
          • 347
          I took it back tonight (9/23/05). Today during school i had installed a honda civic air intake on it. Cut 6 inches off and it workes great. Then i took it to the track. Stupid me on the way filled up with gas, i still dont know why i didnt on the way back. Anyway, My fastest time was a 16.241 @85.62. Not bad for just a $40 intake. Now i need to get a job and buy your chip Ben. And i figured out that when you have an aftermarke intake that you need to keep the thing cool. I need to build a heatshield now. Thanks for most of the replies. I am the car on the right.
          Kyle
          1992 Lumina Z34
          5 Speed
          Autozone civic intake
          Ultra White lights
          FFP Dogbone mount
          125k miles
          2.5 inch Magnaflow catback from Magnaflow cat
          60degreeV6.com Custom Chip
          • JamesonGT282
            • Jan 2005
            • 208
            I am not an expert on the 3.4, but that looks like too much wheel spin based on yout 60ft. Most of my runs as an auto netted 2.20 60 fts and 16.1's usually followed. For every tenth off your 60ft its equal to 2 off youy quarter. So if you can hook up with say airin down your tires or stickier fresh rubber you may see a 15.8-16.0 if you can get from a 2.4 to a 2.2. 15.8-16.0 is where a stock 3.4 auto should be if I am not mistaken.
            '91 Beretta GT 282 swap GONE
            '98 BMW M Roadster stage 2+ boosted
            '06 Saab 9-5 wagon 5mt tuned
            '11 Saab 9-3 XWD tuned
            • RednBlack
              Wood Hippie
              • Mar 2004
              • 2795
              #21
              Mid 16s are average for non modded 3.4s. Shouldn't be much wheel spin stock. I would blame it more on in-experience at launch. I like brake torquing to 2 grand. Less bog and load time at launch. Nice R/T.
              And the change to type F fluid gives a more positive shift. Either have it flushed, or change it 3 times to get rid of the Dexron.
              • Kyles93Z34
                • Dec 2004
                • 347
                #22
                No wheelspin at all actually. I tried the torque braking thing. My brakes are way too bad to get a semi-high RPM with out moving the car. My 60 foot times didnt improve at all. I think that the problem was that my gas tank was full. My previous visit to the track i had a 60* of 2.388. That was on less than a half tank of gas. This time was on a full tank. Could that be the problem? I was wondering if this could be contributed to the timing being off? I really want to get that changed to +6 -6, but i really need a ballpark figure. How much do you think a chip from here would gain me in the 1/4mile? Any one have the dogebone from FFP? Thanks for the help all.
                Kyle
                1992 Lumina Z34
                5 Speed
                Ultra White lights
                FFP Dogbone mount
                125k miles
                • Kyles93Z34
                  • Dec 2004
                  • 347
                  #23
                  And one other thing, is that R/T really that good? I am only 16 and im not really sure what a "good R/T" is considered. Thanks again.
                  Kyle
                  1992 Lumina Z34
                  5 Speed
                  Ultra White lights
                  FFP Dogbone mount
                  125k miles
                  • blackbombshell95
                    Kaiō-ken X 10
                    • Jun 2004
                    • 1386
                    #24
                    i got a 16.21 with a 2.213 60 ft. He could get much better 60 foots with more practice. I get good launches because of my new wide tires and stiff suspension.
                    i bet your car is 15sec capable easily with the right launch
                    • Kyles93Z34
                      • Dec 2004
                      • 347
                      #25
                      How do you launch better with an automatic? Give it gas and have your foot on the brake and wait untill the light gets to the third yellow light and then floor it and let off the gas? I dont see how you could improve your times if you get around the same r/t. The way i did that was to just floor it when the third yellow light came on. How could you improve your technique doing just that? Thanks for the suggestions.
                      Kyle
                      1992 Lumina Z34
                      5 Speed
                      Ultra White lights
                      FFP Dogbone mount
                      125k miles
                      • RednBlack
                        Wood Hippie
                        • Mar 2004
                        • 2795
                        #26
                        Here is a suggestion..Don't crumple your time slips. :P
                        Really, your car is doing just fine for the mods you have, and 1/4 sec R/T is very good. I have had as high as 1.2, but I was under the influence of age.
                        When you go test and tune, you are racing yourself. If you feel good about it, and had fun, it's all good.
                        • Rosez34
                          • Aug 2005
                          • 59
                          #27
                          .2 is good for your first time but not good racing against someone who knows what they are doing. Mess around with your spot on the tree. I leave when the second yellow goes out and go .030 average. Or you could keep your spot and go in deep(turn the top stage light off) and that is usually worth about a tenth off your R\T. BTW my 95 3.4 only goes 15.8
                          1995 Monte Carlo Z34
                          • Kyles93Z34
                            • Dec 2004
                            • 347
                            #28
                            Only? I would shit a brick if i could get mine to run anywhere in the 15s. Will someone plz answer my question about how much they think a timing change would cost if i went to a chevy dealer. Thanks
                            1992 Lumina Z34
                            5 Speed
                            Ultra White lights
                            FFP Dogbone mount
                            125k miles
                              • 13533
                              #29
                              bend over, that sums it up. Why don't you call them up so you know exactly what it costs vs what a bunch of people online are guessing or saying what a different dealership paid? ive heard 600-1200+.
                              • Kyles93Z34
                                • Dec 2004
                                • 347
                                #30
                                Fuck that then. Ben, if i got your chip would you have to adjust for the timing possibly being off? I just really want to get in the 15s.
                                Kyle
                                1992 Lumina Z34
                                5 Speed
                                Ultra White lights
                                FFP Dogbone mount
                                125k miles
