xoneliths Track info
  • xonelith
    • 47
    New pb:
    13.991 @ 99.13 MPH
    All Motor 2001 GA GT1
    HPTuners.com
    MilzyMotorsports.com
    GrandsOntario.com
  • blackbombshell95
    Kaiō-ken X 10
    • Jun 2004
    • 1386
    do u use slicks? any new mods? or did u just drop ur 60ft?
    02 GTP - 90* > Failboat
    www.blackbombshell95.com
    • Mars
      • Apr 2004
      • 826
      I got 13.786 @ 103.47, shitty sate of tune and a plugged cat... Stock 3 year old clutch too.
      • Rosez34
        • Aug 2005
        • 59
        add me to the list.....15.74@87
        1995 Monte Carlo Z34
        • xonelith
          • 47
          No slicks, stock weight.
          Nothin' new.
          I think the cooler weather is helping me. My 60' is better, but I have run quite a few 2.1's, just not 2.12 I've also been workin' on my tune, but I found that my injector duty cycle is at 92% at 6200-6400 rpm. I don't want to try and add any fuel and timing until I upgrade these.
          I'm waiting for an engine mount which I hope to get soon. I'm thinking some of the KR i'm getting is from the amount of movement I have under the hood (we'll see). If it is, I can up the timing again I'm still pretty much at stock timing.
          HPTuners.com
          GrandsOntario.com
          • RednBlack
            Wood Hippie
            • Mar 2004
            • 2795
            I'll add anyone who PMs, or E Mails a time slip. Gotta be fair to all.
            • Doward
              • 127
              Damn... gotta get back to teh track then!
              3.1L \'88 Camaro - 16G @ 9.5psi
              222/291 @ wheels
              T61 on the way!
              • blackbombshell95
                Kaiō-ken X 10
                • Jun 2004
                • 1386
                do u have a stock bottom end?
                • xonelith
                  • 47
                  If you are asking me, then yes. Eventually I plan to build it up. My compression ratio right now is around 10:1 due to the headwork, but I hope to increase it slightly (unless I go turbo... not sure what I'm doing yet...LOL)
                  I've been told the bottom end should hold the tiny bit of power I've got. We'll see
                  HPTuners.com
                  GrandsOntario.com
                  • blackbombshell95
                    Kaiō-ken X 10
                    • Jun 2004
                    • 1386
                    u don't want to go turbo with that cam and headers that you have on.
                    • xonelith
                      • 47
                      Some say there is too much overlap, but I'm thinking, it will spool the turbo quicker. My buddy has a big cam in a GTP and the T60 he bolted on, spools up nicely!!
                      I have to do some more research, but I'll figure something out
                      HPTuners.com
                      GrandsOntario.com
                      • xonelith
                        • 47
                        why are there 2 of these threads? One by bszopi and one by redandblack? Which one is primary?
                        HPTuners.com
                        GrandsOntario.com
                        • RednBlack
                          Wood Hippie
                          • Mar 2004
                          • 2795
                          Brad was the moderator of this forum, but I stole it from him. :P
                          Actually this forum was my idea, and I'm happy to be able to moderate it. He was nice enough to let me. I wasn't going to delete his thread, but he did already. All the info was transferred. Thanx Brad.
                          And with that, I am going to split this thread to let you have your own, to tell your tech info.
                          • xonelith
                            • 47
                            LOL... cool, but you can delete my posts. I wont' be offended.
                            HPTuners.com
                            GrandsOntario.com
                              • 13533
                              How does 203 hp at the wheels = 13.99? Have you done a lot of weight reduction? Trans mods? I just can't figure it out when 218 at the wheels in a Z34 5 speed = 14.6 and the weight should be damn close between the 2. Gearing should at least offset that since its close ratio for the 284.
