Yes, the ECM is under the coolant tank. Use a 10mm wrench to get it out of the holder and then a 1/4" socket to get the panel off.
I took the 5 speed Z34 to the track...
How hard is the coolant tank to remove? If its not hard i will go and get the #s right now.
Kyle1992 Lumina Z34
5 Speed
Autozone civic intake
Ultra White lights
FFP Dogbone mount
125k miles
2.5 inch Magnaflow catback from Magnaflow cat
60degreeV6.com Custom Chip
Its simple. 1 bolt, 1 nut, lift up. Its about as hard as opening the hood.Ben
Will it leak antifreeze everywhere? Just wondering, why do you need the #s off the chip?
Kyle1992 Lumina Z34
5 Speed
Ultra White lights
FFP Dogbone mount
125k miles
I reset the code and after i drove it around for awhile the code 39 came back on. Just 39, not the others.
Kyle1992 Lumina Z34
5 Speed
Ultra White lights
FFP Dogbone mount
125k miles
The car is now throwing codes 32 and 39.
Kyle1992 Lumina Z34
5 Speed
Ultra White lights
FFP Dogbone mount
125k miles
Code 32 is your EGR. Passages are probably clogged. But the EGR itself could be faulty, but unlikely. Mounted on the top drivers side of the engine. 39 is the clutch switch under the dash in front of the pedal. Could be out of adjustment or faulty.
Wow what am I like the 5th person to chime in on this and say the same thing?Lorenzo
