possibility of remote mount turbo
  • loner666
    • Oct 2006
    • 435
    i know his numbers..3400 at 10psi and alky injection..also think he has a TGP chip in it
    i have a 3100 with 5psi..thats it
    Best 1/4mile ET - 12.9
    Best 1/4mile MPH - 111
    1997 Ford Ranger Splash
    Daily Driver
    • gectek
      Banned
      • Aug 2006
      • 1472
      hey loner...have u taken ur car to an oil change place just for giggles and watch them look for the air filter?
      • gboogie99
        they still can't catch me
        • Nov 2005
        • 348
        i have the same problem tuning my car, its a 1995...been trying to find a piggyback system for cheap. Has anybody figured out how to bypass the speed limiter?
        • loner666
          • Oct 2006
          • 435
          not yet maybe i should just for the hell of it
          "Hi, I just bought this car and I cant seem to find the Air Filter. Could you tell me where its located?" lol..
          i have had alot of people at the track scratch their heads trying to find the turbo at the track
          Daily Driver
          • jturkey69
            Red Line or Lick Mine
            • Sep 2006
            • 7
            so where is someone in WI that can help with this on my Alero
            http://www.cardomain.com/ride/615508
            • gectek
              Banned
              • Aug 2006
              • 1472
              #21
              go to www.ststurbo.com and search in your area
              • loner666
                • Oct 2006
                • 435
                #22
                either them or find a mom and pop shop like i did as long as you know how you want it..alot of the big name shops probably wont make it for you (atleast around here anyway)
                Daily Driver
                • gectek
                  Banned
                  • Aug 2006
                  • 1472
                  #23
                  well i know that alot of the companies that sell sts turbos are good places to get custom work like TRT(texas rear turbo), they will do custom work for anything, including my GA when i do it
                  • TurboBeretta
                    • Feb 2007
                    • 9
                    #24
                    Originally posted by loner666 View Post
                    ur 3.4 DOHC has quite abit more power stock then a 3100..plus im only running 5psi right now my engine has just under 128,000miles on it and i havent touched the internals yet..and i cant tune the car so that limits me alot as well
                    stock i ran 16.8
                    What are you using for tuning? I'm still researching how I want to tune my car. I ran a FMU on my crx and it didn run great but it seems like alot of people are having good luck with these units on the GM v6 motors, or at least better than hondas. People are also telling me to run megasquirt but I'm not a fan of that either.
                    88 Beretta GT
                    2.8 5-Speed
                    • IsaacHayes
                      Mr. Orange.
                      • Apr 2006
                      • 6030
                      #25
                      loner666: I might of asked the same question as turboberetta before, but yeah what are you running for tuning? and what year is your corsica?
                      TurboBeretta: A lot of people running boost on 660 gm motors are using the old memcal computers with modified turbo grand prix code. A few are ODBII and using a power tuner/DHP to reflash the ecm. I think 89jyturbo is the only one who is running a turbo with just a FMU alone. If your beretta is 93 or older, you can get a burned memcal or burn your own with code. Check out www.v6z24.com a lot of those guys are running turbo 3400 swaps.
                      My beretta is a 94. ODB1.5 bastard untuneable ecm. :P
                      • TurboBeretta
                        • Feb 2007
                        • 9
                        #26
                        I have a 88 2.8 which is OBD1, so I just have to find the correct bin file? I have a 28-32 pin chip burner that I use for my crx. Is there anything else needed besides for the tgp tune. Also is there a different harness or anything I have to run?. Thanks for ur help
                        88 Beretta GT
                        2.8 5-Speed
                        • jturkey69
                          • Sep 2006
                          • 7
                          #27
                          thanks for the info
                          • 97cutlas$upreme
                            • Oct 2006
                            • 74
                            #28
                            for who ever has this done already, do you have any issues with the air filter sucking up water?
                            97 cutlass supreme
                            3100 sfi
                            cai
                            ud pulley
                            pu dogbones
                            #14 rapidfires
                            magnacore wires
                            • timg
                              • Feb 2004
                              • 718
                              #29
                              The FMU's seem to work well for up to 8 psi or so. After that, other tuning methods are necessary. I have used Split Second's FTC1 with 42.5 lb/hr injectors to replace my old FMU. It runs better off idle and worse at idle (no computer tuning). There are a bunch of piggybacks that can be used to trick the ECU into providing the right fueling. Some of the piggybacks will even drive the injectors themselves.
                              Tim
                              325 whp 350 lb-ft
                              • timg
                                • Feb 2004
                                • 718
                                #30
                                My air filter is in the fender. Without a fender liner, I couldn't drive in the rain. With a fender liner, a monsoon wouldn't be an issue.
                                Tim
                                325 whp 350 lb-ft
