Originally posted by timg
View Post
possibility of remote mount turbo
What ratio of FMU did you use with your old setup? 8:1, 10:1, 12:1? Thanks88 Beretta GT
2.8 5-Speed
same as you..POS 94 ECM..its handling it pretty well..95% of my driving is still "stock" to the ECM..i have 21lbs accel injectors, 255lph pump, and a RRFPR..but that all changes in the next few weeks because im upgrading to OBD2 so i can tune the damn thing..Originally posted by IsaacHayes View Postloner666: I might of asked the same question as turboberetta before, but yeah what are you running for tuning? and what year is your corsica?
My beretta is a 94. ODB1.5 bastard untuneable ecm. :P1994 Chevy Corsica. Parted out. Just a rotting shell now
Best 1/4mile ET - 12.9
Best 1/4mile MPH - 111
1997 Ford Ranger Splash
Daily Driver
i have seen NUMEROUS sts powered t/a s and cameros here in lubbock, and it floods alot, and they have no problem at all, if you are a bit squeamish about it, use the filter wrap, it helpsOriginally posted by 97cutlas$upreme View Postfor who ever has this done already, do you have any issues with the air filter sucking up water?
yes the wraps help..i have driven in many bad storms already and had no problem..believe it or not i had a issue in the car wash with it but wasnt bad enough to hurt anything..just ran alittle funny for a minute but just fine after that1994 Chevy Corsica. Parted out. Just a rotting shell now
Daily Driver
well water isnt the big bad enemy that everyone thinks it is, esp in a setup like this, the heat from the turbo would prob vaporize any water, or at least atomize it enough to cool down the intake charge, just like a water injection system does. i hae seen a r!c3 car here that has his stuck through the hood and he drives just fine...very funny though
Mine was a 12:1. It ran pretty rich under boost though. You could probably get away with a 10:1. You would want to dyno with a wideband to choose the correct one.
Tim1995 Z34 - T04E "60" trim, 42.5 lb/hr injectors, AEM WBO2, FFP UD&DB, 3" exhaust, 2800 stall, shift kit, tranny cooler, Powerslot, Hawk HPS, rear disc conversion, KYB, Eibach, HMS F&R STB, Fittipaldi Force 18" wheels, big stereo, lots more coming eventually...
325 whp 350 lb-ft
