need info before boost is installed
  • sealtrix
    domestic X. tuner
    • Jul 2006
    • 11
    well by now i got all the info i need concerning boost, and thx alot to all that have chipped in their knowledge.. i'm lookin for sum nice heads and ported and polished intakes upper and lower, once i get these then i'll boost it and my ride will be ready....???? where and what r the specifics about the walbro 255l fuel pump thought about adding a electric fuel and keeping stock or should i change the stock alone...let me know fellas , when i get done my ';94 acheiva will be a terror in these parts..thx. u can check the car out on cardomain.com under domestic x. tuner...
  • sealtrix
    domestic X. tuner
    • Jul 2006
    • 11
    ecm reflash
    since i plan on doin all this good stuff to the car can't do without a good ecm retune...where or how can i get this completed, help me out , ur advise will help, it's obd1.5 so i know thats a it's little tricky...
      • 13522
      I didnt have good results from the walbro pump. 60k miles and it fried. Might have been the install (pep boys from when I was living in an apartment in 99).
      You need to get a programmable setup. No one can tune obd 1.5.
      • timg
        • Feb 2004
        • 718
        Since nobody really tunes those, your best bet for engine management is a piggy back. Try a Split Second FTC1. It will do fuel and ignition timing. I have one running on my Monte Carlo. There are other piggybacks, but I don't know of anyone who has tried to use one. If you're just looking for a low boost setup, a FMU/Walbro 255hp fuel pump combo would meet most of your needs.
        Tim
        325 whp 350 lb-ft
