What do you Think ?
  • ezrollin
    • 205
    What do you Think ?
    Checking compressor maps[majestic] the to4e-57 and to4b 60-1 both seem to be in the 70 + eff. for my 3.4 [14.7 / 6000 rpm] .What are the pros/cons for one or the other ?
  • timg
    • Feb 2004
    • 718
    The 60-1 is capable of supporting more power and has a larger inducer on the compressor (both use the same exducer diameter). Spool should be virtually identical. No good reason not to get the 60-1 if those are your two choices.
    Tim
    325 whp 350 lb-ft
    • ezrollin
      • 205
      Yes I agree. I was searching for some prices after I made the post and ran across this at Turbo Elements : T04B 60-1 comp. 60 trim .70 ar Turbine. p trim 58-96 ar and T3 / 60-1 comp 60 trim .70ar Turbine stage 3 wheel .63ar both deliver 61 lbs/min Does the first one have a bigger turbine ?
      • Guest
        screw that mid 80's technology and join the new age. GEt this
        cheaper then a ball bearing and much better then a 60-1 wheel
          • 13531
          how much are the others?
          • ezrollin
            • 205
            The to4e is $575 the t4 60-1 and t3 60-1 $695
            • timg
              • Feb 2004
              • 718
              Of the two you posted, the first one does have a larger turbine wheel. Turbo Elements runs specials on Honda-Tech that beat the prices on their website.
              The SC61/PT61/T61 turbos that use the compressor from the GT35R are great turbos and can sometimes be found for under $650 during sales.
              Tim
              325 whp 350 lb-ft
