compression ratio
    Live life 3.7mi at a time
    • 4555
    Originally posted by vega View Post
    sweet so either i read that site wrong or that site was wrong.
    forcedfirebird how did you get 11.78:1? for math that is? whats the equation? if you will.
    3400 heads on a .030 over 3.1
      • 9191
      As far as the math goes, try the CR Calc here on the site, located on the Site Navigation sidebar menu, at the very bottom.
        • 4555
        that is how it was calculated
        11.74:1 with the stock sized pistons and 11:92 with .030 over, sorry I was going from memory in the origional statement.
        Still how do you think that would react with boost?
        • vega
          • 57
          btw how much would .030 over be on this smaller engine its different then it is on the 350 or the caddy 500 and i don't know the math to that either.
          You know that sun viser that doesn\'t quite go down when the sun is there and then when you are driving with it down and you can\'t see the stoplights ? Well... that\'s why my fiero isn\'t at the shop yet....
            • 4555
            Do you mean how many liters it would displace, how much more compression, or how much more power?
            • vega
              • 57
              #21
              liters/cubes
                • 4555
                #22
                Well, if the stock piston is 3.504 and you add .030" would be 3.534. Miltiply this by the stroke (3.307") and get the CI total...
                Stock = 191.237196 cubes
                .030" over = 194.530719 cubes
                Calulate this by multiplying 3.14 by radius squared (1/2 of diameter/bore) by stroke.
                Converting to liters is a whole nother story, lol .
