Choosing a turbine A/R Ratio
  • project89
    • Sep 2008
    • 247
    use at minimum a t3 .63 housing, i would see 12 psi by 3k in first gear with my old t3/t4.the .84 housing im running now is a lil laggier but deff makes more power uptop (6k+ rpms)
    and dont worry about the motor choking above 5k cause it wont, boost a stock motor and it will pull all the way to redline if the turbine housing dosent choke it
    #1 1989 RS - THE L98 AND LT1/LS1 KILLER
    1LE SUSPENSION AND BRAKE SWAP,3.1L V6 8.5-1 CR, LIGHTENED CRANK,KB COATED PISTONS, CUSTOM 268/272 DUR CAM, CNC'ED HEADS, PORTED INTAKE,CUSTOM TURBO KIT W/ 67MM TURBO(AKA TO4R/Z) 28 PSI, TCI STREETFIGHTER 700R4 W/ TCI 4,500 STALL,ALL RUN BY A MEGASQUIRT ENGINE MANAGEMENT SYSTEM
    #2 95 granprix 3100 all stock for now
    ported heads and cam comming soon, megasquirt ems and turbo down the road
    • TiredGXP
      • Jun 2008
      • 107
      Well, it's done. Ordered the T3/T04E 50 trim compressor and .63 A/R Stage III turbine today. Found one with a water cooled, ball bearing center section for a comparatively reasonable price at AP Tuning.
      Turbine housing has a T3 inlet and 5 bolt Ford style outlet. Picked up a stainless T3 inlet flange and stainless "ultimate" internal wastegate with 3" v-band outlet.
      Still need to find the right wastegate actuator....
      • timg
        • Feb 2004
        • 718
        That should work well. It won't give you peak power, but will give you an awesome street powerband.
        Tim
        325 whp 350 lb-ft
        • TiredGXP
          • Jun 2008
          • 107
          Tim
          That's exactly what I'm looking for.
          • TiredGXP
            • Jun 2008
            • 107
            So, the FedEx truck came by and dropped off an interesting box
            Here's the T3/T04E turbo:
            A shot of the turbine exit
            And another looking through the 3" v-band "Ultimate wastegate"
            So the plan is to use this Sy/Ty W2A intercooler
            and this dual 48mm LT1 throttle body (same one as used on the Sy/Ty)
            Finally most of the big ticket items have arrived.
            Still need to finish the design parameters of the sheet metal intake that will be needed for the throttle body, and fab up both it and the exhaust system. Then, of course, it's being nickled and dimed to death with oil and water fittings, hoses, clamps, W/G actuator, W/G solenoid, BOV.......
              Live life 3.7mi at a time
              • 4555
              #21
              I understand that nickle and dime effect all too well
              • TiredGXP
                • Jun 2008
                • 107
                #22
                Yeah, we just signed the documents to buy a new house yesterday, so I expect that I'll probably have to spread out, or defer, car part purchases until we finish paying for landscaping and fencing.
                Had plans for body mods to the Fiero, including new side scoops, recessed headlights, F355 front bumper, hood vent, changing the profile of the notchback, adding a rear spoiler... I guess body mods and paint can wait until next year...
