IAT sensor placement?
  • Daguse5853Z
    Here's yer sign
    • Nov 2003
    • 155
    Intake air temp sensor on obd2. Going from NA to turbo. It makes sense it should be after the IC close the the throttle body, right?
    95 Z26 3400/OBDII/GETRAG
  • Azrael
    Accelerating uphill in OD
    • Apr 2005
    • 763
    It's always a good idea to let the computer know the conditions of the air right before it enters the engine.
    1995 Grand Am SE
      X2, i would want it as close to the TB as possible.
      • RedZMonte
        • Feb 2004
        • 1378
        my IAT sensor is about 6" before the TB after the IC. If it helps you can buy a IATs for a 1991-4 Syclone/Typhoone or a 1989-90 Turbo Grand Prix they have the same connection but they are threaded (brass fitting). I drilled a hole in my charge pipe and screwed it in, Works great and won't pop out under boost or cause leaks.
        S
        Shane "RedZMonte"
        1992 Lumina Z34-VIRGIN (RIP)
        1992 L67 Lumina Z34 (SOLD)
        1990 Turbo Grand Prix (SOLD)
        • AleroB888
          • Nov 2009
          • 249
          I run mine in the intake manifold :
          That's the best location for an accurate reading of what the engine actually sees after boosting and intercooling.
            • 13520
            The TGP motors had the IAT in the manifold as well, and the best location to measure is near the intake valve. I think the IAT parameters in the computer that compensate fuel and spark would be different though depending on where you get your readings from. Since this is NA to Boost, I would say closest to the TB or behind it so long as you prevent heat soak from skewing the numbers.
            • timg
              • Feb 2004
              • 718
              I would also put as close to the stock location in the intake as possible, but after the turbo. If you have a push in sensor, either put it before the turbo or replace it with a screw in sensor.
              Tim
              325 whp 350 lb-ft
