Best 3400 UIM for boost
  • Z26-T
    • Apr 2008
    • 486
    So which UIM is preferred or boost? Those I've asked haven't noticed a difference from a ported 3400 to a 3500 UIM on N/A. Which one flows better, if either with forced induction?
    So my options are gasket matched 3500 UIM with 65mm TB Or 3400 UIM ported to match 65mm TB and 3500 lower. Will be using 3400 heads/LIM until I can get some ported 3500 heads/LIM.
  • Mars
    • Apr 2004
    • 826
    Good question. I was in the same boat as you and went with the 3500 upper and a 65mm TB.
    The 3500 upper has Shorter runners; which usually means more top end power. (Our V6's already make gobs of bottom end, so why not give some up, to gain up top).
    That was my reasoning behind choosing the 3500 upper.
    • 1988GTU
      LB62LHObbqftmfw
      • Nov 2005
      • 2475
      3400 is better, but you'll lose the awesome looks of the lx9.
      • Z26-T
        • Apr 2008
        • 486
        True.. Not sure if I want to lose that look... But the cool thing about the 3400 UIM it's actually a wide port 3100, so it'll look even cooler than the lx9!
        Thanks for the info.
        • 1988GTU
          LB62LHObbqftmfw
          • Nov 2005
          • 2475
          Originally posted by Z26-T View Post
          True.. Not sure if I want to lose that look... But the cool thing about the 3400 UIM it's actually a wide port 3100, but it'll never look cooler than the lx9 still!
          yep no prob
          • RedZMonte
            • Feb 2004
            • 1378
            I like the look of the 3400 Intake best. Honestly under boost its not going to make much of a difference between the 3400 and 3500 intakes. NA now that might be a different story. I realize every bit of flow you can get the better but when boosted, it flows just fine. (under the impression the 3500 Intake is better flowing....)
            Shane "RedZMonte"
            1992 Lumina Z34-VIRGIN (RIP)
            1992 L67 Lumina Z34 (SOLD)
            1990 Turbo Grand Prix (SOLD)
              Until you go to boost, if I remember correctly.
              • RedZMonte
                • Feb 2004
                • 1378
                OK, I will play your game.... lol
                As long as you have the large port 3X00 intake then i wouldnt bother swaping for anything else. You can see the difference here:
                Shane "RedZMonte"
                  Yeah, that pretty much is what I meant. Large port 3100, or 3400 is better for boost over a 3500. NA then grab a 3500 upper (from what I was told, again, IIRC- but we all seem to agree).
                  • 1988GTU
                    LB62LHObbqftmfw
                    • Nov 2005
                    • 2475
                    I don't think I'd have gained much more going with a big port upper versus my lx9's. Until we see real result from someone trying both, I think this speculation is just that, speculation. We all knows what happens when crude oil is speculated, it'll go up or down as a result. Lets not use that same false of judgment with an intake manifold!
                      Well, as I've said in previous posts, as long as my memory isn't failing me, this is what I've been told. Told by a certain somebody with a flowbench He hasn't come in and said otherwise, and what I'm thinking agrees with others, I think we are on the right track.
                      • 1988GTU
                        LB62LHObbqftmfw
                        • Nov 2005
                        • 2475
                        Correct, I never said the lx9 performed better. Just saying the offset of performance is not worth going to a part that's hard on the eyes.
                        • kwhauck
                          Olds Sleeper
                          • Aug 2006
                          • 379
                          What about the 3400 LNJ UIM?
                          • kwhauck
                            Olds Sleeper
                            • Aug 2006
                            • 379
                            anybody?
                              • 13531
                              With the TB on top? It flows more evenly than the LX9 upper.
