Air Fuel Ratio and Timing for Boosted 3400
  • TGP37
    Shadetree Engineer
    • Jul 2011
    • 1027
    From what I am reading/learning, an EGT Gauge can help with boosted AFR's. I read the higher the EGT's under load equals more power. Especially a turbo as the heat is the primary force that drives the turbine.
    So leaning the AFR under boost will increase EGT's. Likewise adding fuel will bring temps down. Unless your beyond stoich going lean, but if the engine is running leaner then stoich in boost......there is a bigger problem, lol.
    AleroB888: An EGT will be a blessing if you want to lean out the AFR's. But it isn't an exact science, as I learned. Placement of the EGT Sensor will determine over all temps. This is why I mounted mine as close as possible to CYL6 (the assumed hottest cyl).
    Now, I'm curious of the max safe EGT for our engines? Anyone know?
    Time to upgrade to a higher output injector set while taking care of any other fuel restrictions.
    I found upgrading to a larger diameter fuel line reduced restriction which in turn boosted the fuel rail pressure. That could be a cheaper solution versus new injectors above 36 lb/hr. Stock I was around 43 psi. With a -6AN Braided Stainless (3/8") my fuel rail pressure jumped to 60 psi. I also have a high flowing fuel pump, but not high pressure. Only need basic adapters at the rail and fuel filter.
    Or get a WOT-TECH Adjustable FPR
    Or get a boost referencing 6:1 FMU
