Air to CO2 intercooling!?
  • ericjon262
    build it.
    • Jan 2010
    • 2218
    Thought I would share this to the Turbo dragstrip guys...
    There's been some interest in this in a few other threads and in PMs, so I'll ramble on a bit about it here. Any questions, comments, advice, ridicule, etc, are always welcome. :) This is the same concept applied to diesel motors, and different from twin turbo, sequential turbos, etc. Diesels...
    if you read the last post and the posts on the following pages, they hacked up a A2w core and mod'ed it to run CO2 through them and maintained 70* manifold temps! wouldn't do a damn bit of good on the street, but still pretty cool...
  • caffeine
    • Jan 2012
    • 1489
    Hmm makes me wonder about running the A/C system through an a/w intercooler...
    '86 Fiero, 3500, 4-speed
    • ericjon262
      build it.
      • Jan 2010
      • 2218
      the trick would be controlling the flow through the core so you don't ice up, also, the A/c system is closed loop, so you have to valve it so that you can divert away from the evaporator, and to the intercooler without opening the system, and then there's the issue of programming, because PCM's automatically turn off A/c at WOT. not sure if it would be easy or not to turn that off.
      also, lets not forget that the compressor takes power to run, so it has to cool the air enough to make more power than it takes to run the compressor at WOT.
        If the charge going through it were ambient, I could see that. Considering how hot some air charges get I would think it might be worth at least testing.
        • caffeine
          • Jan 2012
          • 1489
          The nice thing about running the a/c system through is that the intercooler would never get heat soaked and colder-than-ambient temps should be possible at all times.
          Anyone know how much power an a/c compressor takes to drive on average?
          • AleroB888
            • Nov 2009
            • 249
            No, I'd bet a lot that's too inefficient a method for continuous operation, consider how long a fridge or AC vent takes to bring the temp down from the instant it switches on.....
            Possibly for pre-cooling prior to a run, though. But it can pre-cool a water reservoir which in turn pumped into the core chills the charge.
            • ericjon262
              build it.
              • Jan 2010
              • 2218
              I bet if you ran R22 or another really BA refigerant through it it would work.
              • Guest
                Mustang guys do that. Google killer chiller.
                  I think the early sc lightning do stock too.
                  • caffeine
                    • Jan 2012
                    • 1489
                    Ya I would think that even if the a/c is disabled under wot it would keep the air cold for a bit anyway. And if you've warmed up the car enough for a wot run with the a/c turned on it should be pretty cool.
                      You could always wire up a wot switch like for nitrous to keep the compressor on.
                      • ericjon262
                        build it.
                        • Jan 2010
                        • 2218
                        I wonder if the belt would hold it?
                        • caffeine
                          • Jan 2012
                          • 1489
                          If the belt couldn't hold it then it would probably be taking more power to drive it than it would be worth
                          • ericjon262
                            build it.
                            • Jan 2010
                            • 2218
                            I just started thinking about that, and if it's slipping, it would be taking extreme amounts of power to work...
                              I really doubt an ac compressor at wot is going to require more power than it would at idle. The pcm commands it off to give maximum power when wot is needed.
