how much boost will a stock motor handle
  • tjbecht
    • Nov 2004
    • 15
    how much boost will a stock fwd 3.1 motor handle??
    • 9191
    6 or so psi...
    • slowbird
      • Nov 2004
      • 15
      I know a guy who was running 10psi on his stock 3.1 Cavy.
      He swapped in a 3400 (The 3.1 didn't blow up or anything) and he's now running about 10psi on that stock motor.
      So....10psi
      • tjbecht
        • Nov 2004
        • 15
        ok well what car should i get a turbo off of what about a thunderbird turbo coup
          • 13533
          If the stock bottom end can take a 250 shot a few times and not die...id say you can safely boost it quite a bit with proper tuning. PSI depends on the turbo and any other engine work.
          • Anonymous
            Those were only like 2.3L 4 cyliners, I'd say you'd need bigger considering the stock turbo on the TGP is on the small side.
            • Guest
              *looks at avatar* Hmm, yep Ford Turbo coupe turbo, works well.
              i did find that in my application it was probably a bit on teh smallish side, but there were other factors that are being changed along with the turbo I'm changing.
              Don't assume by engine size that a turbo will be too small or too large, there are other factors involved.
              • mcgavinz26
                • Dec 2004
                • 84
                13.76psi
                anymore and you will instantly destroy the engine
                1988 Fiero GT 5spd
                1999 Regal GS
                SOLD 2000 C5 Coupe M6
                RIP 1994 Beretta Z26 - M90, 3400, MSV3, 5spd
                • Anonymous
                  Originally posted by mcgavinz26
                  13.76psi
                  I wouldn't trust it with anything more than 12. Especially on the stock ignition/ECU. Hell Luke's TGP(running 11.5), HAD to run premium, and knocks slightly with anything less than premium.
                  • Doward
                    • 127
                    Im running 9.5psi, 16G here. 222.4 rwhp / 291.2 rwtq 93 octane, running about 16º total timing, for now. I'm going to start bumping it up, after I get a WB02
                    3.1L \'88 Camaro - 16G @ 9.5psi
                    222/291 @ wheels
                    T61 on the way!
