3.1 TGP bin runing a 3.4 DOHC
  • 93gtpdohc
    • 107
    Has anyone moded a 3.1 tpg bin to run a 3.4 dohc? i;m currently in the process of doing it, and just wanted to know if anyone else has done it and could help me out
    04 Escalade 6.0L
    08 Z06
    96 Blazer SFA
  • TurboGTU
    • 453
    RE: 3.1 TGP bin runing a 3.4 DOHC
    You have a 5spd..that is a walk in the park conpaired to a member here doing it to the Auto intergration. He was thinking of going OBDII last time I remmebered. You should be oright..Just hit up GMPCM for the 5spd patch file for the 8f code. I think it mods the TCC tables for shift light???not sure about that. THe guy (i can't remember your name..sorry..been a while) that did the conversion should be here.
    • 5speedGTP
      • 10
      TGP bin
      Go over to www.fiero.nl and look for Darth Fiero. Ryan is a great guy and has done the mods to the bin you want. He is really reasonable and very helpful. Hope that helps.
      Greg
      • Doubt_Incarnate
        I still watch ROBOTECH!
        • Jan 2005
        • 1130
        isnt there a cam sensor on the tdc motor? or is that just used for injector timing (sfi)?
        • 93gtpdohc
          • 107
          i did the converison to 5 spd, and also a turbo set up http://www.cardomain.com/memberpage/369376/1
          and nope theres not a cam sesnor,
          04 Escalade 6.0L
          08 Z06
          96 Blazer SFA
          • 93gtpdohc
            • 107
            5speedGTP
            you wouldn;t happen to have Darth Fiero email address by anychance?
            04 Escalade 6.0L
            08 Z06
            96 Blazer SFA
            • 5speedGTP
              • 10
              Contact Info
              Here is Darth's web page and his email. Like I said before, Ryan will work with you and get what you need onthe chip.
              darthfiero@att.net
              Greg
              • 93gtpdohc
                • 107
                You know what funny is he is already helpin me with it, it just clicked in, cause i found him though the www.gmtuners web site, thanks tho,
                04 Escalade 6.0L
                08 Z06
                96 Blazer SFA
                • Kohburn
                  custom fab-whore
                  • Apr 2005
                  • 165
                  yeah Darth burned my 3.1TGP chip to run my 3.4dohc -- i am not runnign boost to it yet and just got it fired up last night.. i'll be in contact with him and I test it and if there is any tuning necessary.
                  • Kohburn
                    custom fab-whore
                    • Apr 2005
                    • 165
                    not on 91-93 engines, but 94-96 were sfi and have a cam sensor - its only used for sfi so when using the TGP ecm and running it as mpfi you can plug it.
                    • 93gtpdohc
                      • 107
                      kool, my car is going to get dyno and start tuneing maybe this week, so i'll be gettin some #'s soon,
                      04 Escalade 6.0L
                      08 Z06
                      96 Blazer SFA
                      • 93gtpdohc
                        • 107
                        my car got dyno tonight, and my highist run was 212 front wheel hp, @ 7.5 psi with #36 injectors, with a a/f ratio at 12:1, and that was with cat back stock exhaust,
                        04 Escalade 6.0L
                        08 Z06
                        96 Blazer SFA
                        • TurboGTU
                          • 453
                          Those are some good numbers! I see you got your A/F ratio stright. Got a graph of the dyno?
                          What looks like to me is that you need more turbo. I saw on your site you had what looked like an early regal turbo. It looks like the one used on late 70s. They used a electric feedback Q-jet instead of FI. It has like 5 or 6 bolts on the inlet housing don't it?. I think it was a .45 a/r turbo. The turbine hosings are .80 I think. You need a t04 compressor setup. The turbine is fine. BUT overall...its awsome.
                          • 93gtpdohc
                            • 107
                            actually, that turbo behav's great on that motor, it doesn;t start build boost until around 3, right were the power band starts anyways, and keeps a constant boost right to redline, but i was haveing problems with my stock exhaust for restriction last night, it is just too small after the cat, and one of the mufflers is starting to developed a hole in it, i think it got 6 bolts on it, the turbo was off of a 83 regal T-type, the exhuast a/r is .83, i forget what the compressor side is, and i forgot to get a print out, next time i go i will, i got small video of one pull, when i learn how to upload i will,
                            04 Escalade 6.0L
                            08 Z06
                            96 Blazer SFA
                            • Froggx
                              • Jul 2004
                              • 385
                              by chance did you get a pic of your dyno chart?
