no, i forgot, to get one, but i;m gonna bac this week and get a print out of my last run, can;t wait she goes bac on the road hopefully on thurs day
3.1 TGP bin runing a 3.4 DOHC
he gave me a bin file that he moded, but i ended up completely redoing all of the ve tables/spark table, my runs good under boost with the #36 injectors, but still needs a little tweaking for idle, i;m just waitin for my wide band o2 senor to come in, then i'll get it all tune up, if u want i probly could send u copy, for stock injectors, my car ran fine with them before,04 Escalade 6.0L
08 Z06
96 Blazer SFA
#36 injectors.. what are the stockers, 19#?Originally posted by 93gtpdohche gave me a bin file that he moded, but i ended up completely redoing all of the ve tables/spark table, my runs good under boost with the #36 injectors, but still needs a little tweaking for idle, i;m just waitin for my wide band o2 senor to come in, then i'll get it all tune up, if u want i probly could send u copy, for stock injectors, my car ran fine with them before,
I'm running the stock injectors and a walbro fuel pump
if only you had the wideband and tuned it for the stock injectors all i'd need woul dbe an exact duplicate of yours
good to knowOriginally posted by 93gtpdohcthe stock 3.4 dohc are #24,
so how much power are you putting to the 3.4 that it needs that much fuel?
aren't 24# injectors capable of 300 hp when run SFI and a lot more batchfire?
I'm still on the learning curve for boost so this is good info.
well , i brought them thinking that i needed that much fuel(still learning as well), and that i was haveing problem with my stock ones, leaking like a bastard and not wanting to spend money on another set of injectors, when i already have good set of #36, so that's part-ly why and it leaves a large room increasein power, with out going lean04 Escalade 6.0L
08 Z06
96 Blazer SFA
I am only planning for 250-265hp at the crank so I am going to stick with the TGP 22lb injectors for now.....I hope that wont come back to bite me in the arse.'91 Beretta GT 282 swap GONE
'98 BMW M Roadster stage 2+ boosted
'06 Saab 9-5 wagon 5mt tuned
'11 Saab 9-3 XWD tuned
thats cool, i think i'm gonna stay around 8 half to 10 psi for now, i think once i finsh my new 3 inch exhaust, and play with timeing abit, i should be abl to break 250 whp, right now i'm seating at 212 whp at 269 footpounds at the wheels, and that was at just a little less then 8 psi, and i'm gett;n my dyno sheet scaned today hopefuly, and i'll be postin it my site when i get, but i;m not far off of my goal for whp, know hopefully the rest of the car holds up,04 Escalade 6.0L
08 Z06
96 Blazer SFA
