WTB: A new PROM - 3.1
  • KlingonFiero
    • Mar 2007
    • 68
    Hi All,
    Hope this is in the right spot, still kinda new to this forum.
    I just picked up a 16149396 ECM, but it is from a DOHC motor (92-93 Lumina or a Monte Carlo - really do not recall a the moment...)
    The Raven has said I need a new PROM, since the tables are different.
    Does anybody have one? or does anybody know someone that reprograms the PROM's ???
    Thanks a lot!
    -Don
  • sil
    4T60-E killa
    • Nov 2004
    • 723
    you can use tunerpro and the ads(for scanning) and definition file(for tuning) i made for tunerpro
    the def and ads files are int he downlaod section here
    youll need an adapter for the eeprom chip, the stock prom plugs into the adapter to retain the knock sensor curcuit(i think) and limp mode
    you can use the 29c256 or the sf512 chip in the adapter
    • KlingonFiero
      • Mar 2007
      • 68
      Is there an english version of that???
      I am not quite ready to delve into the world of ECM/PROM tuning. Give me another 6 months or so...
      In the meantime, is there someone I can just pay to do this for me, I just want a stock setup... 3.1 MPFI (gen II) and the 4T60E.
      Thanks!
        • 13500
        93 3.1 W body 4T60E work? 3.33 FDR.
        If you want to send me your memcal, I will solder a new chip and put the stock 3.1/4T60-E code on there for $20 shipped back (no paypal). Then when you want to get into tuning it yourself, you will be able to use that to write to. Or for $30, ill give you an adapter that you plug your stock chip into and then both into the stock ECM. This is easier but is better suited for keeping your stock code for backup, which that won't really help you with.
        What exactly are you working with though?
        • KlingonFiero
          • Mar 2007
          • 68
          I would be more than happy to send you my chip to work with. Especially for only $20.00 !!!
          My engine:
          Stock 3.1 block from a 91 Lumina (including Pistons, Cam, lifters)
          Heads/Intake/TB.Timing Cover/Alternator/etc??? froma 92 Buick Regal
          The trans is from a 94 ??? The only info I found it , based on the trans ID tag is:
          Model Code Description - 4BLW
          Differential - 3800 W Body (4-bolt side cover)
          Ratio - 3.06
          Sprocket Ratio - 35/35
          Overall Ratio - 3.06
          VSS Reluctor - 31
          Stall Speed - 1897
          It is mated to a 3800 engine, but not for long
          Sent you a PM...
