WTB obd1 engine wiring harness
    • 13464
    If its not the w body setup, I will need the ECM as well.
  • CNCguy
    Bisong eater :P
    • 1017
    I have a harness here that Dennis gave me. I'm not sure what they came out of but I assume a W-body since they have plugs that match the 16149396 ECM. It's yours if you want it. Speaking of Dennis, what the hell happened to him? I emailed him a couple of times but got no reply. Did he get lost or something?
    MinusOne - 3100 - 4T60E
    '79 MGB - LZ9 - T5
    http://www.tcemotorsports.com
      • 13464
      He probably has the 94-95 wiring with MAF. I can use most of it if it is. I haven't seen him for a while now so I dunno what happened to him.
      • CNCguy
        Bisong eater :P
        • 1017
        When do you want it?
        Someone had given Dennis three harnesses and he didn't know what they were for and passed them on to me. I chopped one up, gave one away and the other is here. I think the 94~95s have different plugs than the OBD-I's. They are shaped the same but are keyed differently.
        '79 MGB - LZ9 - T5
          • 13464
          94-95 has the same plugs for the DOHC ecm. We will be getting the other conversion parts some time so I will just have you ship them all at once.
          • 1988GTU
            LB62LHObbqftmfw
            • Nov 2005
            • 2475
            Would you need just the engine harness IF I could get you an OBD1 harness from a (1988- 1993) beretta/corsica or maybe a (1989-1993) cutless? or would you need the interior harness as well? Also, what would you be willingly to pay?
              • 13464
              I will modify whatever marc has unless I find out the pin out to the ECM was changed for some reason.
