FS various 3400 stuff from my 02 gagt
  • gectek
    Banned
    • Aug 2006
    • 1472
    1. front crank sensor bought it brand new from GM, actual GM part, asking $10 shipped, used but in good condition - sold
    2. brand new ECT sensor, never used from GM, actual GM part, $10 shipped
    3. LIM cleaned stock...$40 shipped.
    4. both lower control arms from my 02 for sale with brand new GM ball joints(ball joints never used) rivets are drilled out and bolts put in their place for easy replacement if need be. (bushings in ok condition, had to replace both the vertical ones, one got messed up by the press on the steel sleeve, but is ok to use...$25 shipped a piece
    5. outer tie rod ends for sale(used for 1k miles), both sides, comes with jam nut and nut for threads on the knuckle, $13, just need grease, i cleaned them out
    6. used left(drivers side by wheel) trans mount, has 4 mounting holes, in like new condition, painted the alum housing black, $25 shipped
    7. used right(pass side) engine mount, has 4 studs, 2 on top 2 on bottom, in very good condition, asking $25 shipped.
    8. knock sensor used, still works perfectly, $10 shipped.
    9. also for sale my old Harmonic balancer with the tone ring intact...$30 shipped
    10. also my idler pulley for sale...$10 shipped...just pulley doesnt include bolt, shim or plate
    11. also add in my old water outlet housing, minus the brass fittings...need them for the new one. in very good shape - $10 shipped
    • 13522
    Ill take the LIM and knock sensor.
      • 9189
      Got pics of the control arms? I DOUBT they will fit my Beretta, but you never know...
      • geldartb
        The Situation
        • May 2004
        • 1994
        to save you the trouble they wont brad. i was trying to fit some of the aluminum ones on my beretta.
        the spacing is off for the verticle and horizontal bushings.
        99 Grand Am GT
        1357 cam 227 233 .050 dur
        515 515 lift 112 lsa
          • 9189
          Yeah, I ended up looking on ebay. It appears the 94-98 GA ones would work, but not the 99+. Oh well...
          • karateguy62
            3100 V6
            • Nov 2006
            • 13
            I just cracked my lower intake manifold... I really need a 3400 one so if your still selling I NEED it! Thanks
            • gectek
              Banned
              • Aug 2006
              • 1472
              dang i got alot of people asking for the LIM now...i have 1 guy on gagt asking about it, he asked first, so he gets first dibs, but at 7 tomrrow its open game, ill leave that in the open so everyone knows...also give me ur address ben and the knock sensor is urs...my paypal is john_ginter@yahoo.com
                • 9189
                You wouldn't happen to have an old steel wheel (15x6) lying around would you? My wife managed to bent one on our Alero (same one she did less than a year ago!!), so I need to replace it AGAIN! Thanks.
                • gectek
                  Banned
                  • Aug 2006
                  • 1472
                  i actually have 3 old ones laying around, they are the torqed 5 spoke brand new for the 02 year in painted grey...originally make by enkei...asking $75 shipped with the wheel cover(center part) umm ill post a pic if i can find one
                  here it is
                  • gectek
                    Banned
                    • Aug 2006
                    • 1472
                    also on a newer note, the LIM is up for sale again, 1st guy passed on it
                    • gectek
                      Banned
                      • Aug 2006
                      • 1472
                      ok knock sensor(pending bens input) will be sent asap and front crank sensor will be sent off today, the LIM that was sold will be sent off tomorrow...but also add in one more item for sale
                      also add in my stock flexplate(auto trans flywheel) ill even sand blast it for yah...$40 shipped
                      • gectek
                        Banned
                        • Aug 2006
                        • 1472
                        u still want the knock sensor, $10 shipped ben, paypal is john_ginter@yahoo.com
                        • gectek
                          Banned
                          • Aug 2006
                          • 1472
                          knock sensor now sold, itll be shipped tomorrow
