Cylinder Heads 3.1 TBI
  • McLin
    • May 2008
    • 13
    Wanted Cylinder Heads 3.1 TBI
    By Carfax stand this:
    VIN 1GNCU06D8LT11****
    Year/Make/Model: 1990 CHEVROLET LUMINA
    Body Style: SPORTS VAN
    Engine Type: 3.1L V6 MPI OHV 12V
    Manufactured In: UNITED STATES
    Search Results: 1 record found in our database
    I need for this Engine Cylinder Heads....
    Best regards McLin.
    Are they iron heads? If so lots of 2.8/3.1/3.4 RWD heads would fit (all same)
    • McLin
      • May 2008
      • 13
      I found this on:
      Rebuild
      FWD, APV, Transport, block #653, 519, crank #981, cast iron heads, with distributor.
      Best regards McLin.
      • 2.8RS
        Cone Murdurer
        • 196
        I was going to say that a set of heads would be easy to find in a junkyard but I see that you are in Germany. But check out Ebay, there is usually a few heads for sale on there.
        00 Grand Prix GTP Daytona
          Live life 3.7mi at a time
          • 4555
          I have a set that came off my 3.1 and were running strong (blew the bottom end from turbocharging).
          I'll let you have them for a reasonable price, but shipping would be expensive.
            • 13496
            I knew you would have a set:P
              • 4555
              Actually have a couple, but the other set is no better than boat anchors, lol.
                • 13496
                I need to flow the iron head with and without the complete manifold setup someday.
                enough of the off topic though:P what would it cost to ship a set of heads to germany? I dunno what they weigh.
                  • 4555
                  A complete iron head top end weighs 84lbs IIRC, then you can subtract about 14lbs for the manifolds.
                  I Could send you a head and manifolds if you want (the junk ones will work), but I already have flow numbers for stock and SuperSix porting - thanks to turboproject...
                  • 1988GTU
                    LB62LHObbqftmfw
                    • Nov 2005
                    • 2475
                    Shipping will be about 150.00 IIRC. lbs + size of those heads just adds up.
                      • 13496
                      I can get a head local probably but could use manifolds. Nice to see those numbers are close to mine. 3.4 DOHC pwns on the bench.
                        • 4555
                        Probably because some of them ARE your numbers
                          • 13496
                          oh. well then nevermind:P I like comparing off the same bench cause each setup is different. I use a tube for the exhaust and if you don't, those iron head 3.4 numbers look realistic for gen 2 for the most part.
                            • 9179
                            IIRC, he is coming over to the states in a month or so, so he could pick them up and take them back on the plane with him.
                            • 1988GTU
                              LB62LHObbqftmfw
                              • Nov 2005
                              • 2475
                              ^ Don't you mean Weba is?
