Ported heads/LIM gtz trans w/v6 bellhousing fs
  • MidnightriderZ24
    • Jan 2005
    • 699
    ive got a few things for sale. first is a set of 00 3400 heads that are ported. they were gasket matched, ported and have bowl work. comes with ls6 springs installed. i sandblasted them clean, then hot tanked them at work (still a little paint and carbon though). the valves were also blasted and cleaned up. 220 shipped for the heads.
    next item i have a 00 LIM that was also blasted and tanked clean (still has some small spots of paint that was thick). has one bolt hole broken but all i did was put a bolt up through the bottom and it sealed fine for me (ran 12psi through it). this was also ported and gasket matched. comes with a 180 degree thermostat installed. 65 shipped.
    i have a 1990 Quad 4 282 with a swapped v6 bellhousing for sale. it has a lower 2nd,4th and 5th gear which is a noticable difference over the v6 trans. the trans is in perfect working/shifting condition with 67k on it. comes with the stock diff installed (also comes with a stock mounting bracket, its pictured with a modded one for the turbo downpipe) i removed the team green lsd to install in my other trans. 320 + shipping or pick up!
    [SIGPIC]
    12.268@117... 11's to come!
  • MidnightriderZ24
    • Jan 2005
    • 699
    bump, B.O on heads/intake
    [SIGPIC]
    • MidnightriderZ24
      • Jan 2005
      • 699
      bump, for trans! it dropped my et n/a from 14.8 to 14.2 just from the gearswap!!
      [SIGPIC]
      • silvergtjrad
        uber slow grand am
        • Feb 2007
        • 302
        Will that transmission bolt up to a 3400? Im not too familiar with the manual transmissions
        • MOTORHEAD
          • Mar 2008
          • 90
          this 282 getrag came off on what body?
          -1992 Red Z34 284
          -1990 TSTE
          -1991 GTP
          -1992 B Z34 parts
          -1992 R Z34 parts
            • 13522
            You would need a different bellhousing but that shouldn't be difficult given the 282 was available with the 60V6 pattern.
            • 91LQ1Lumina
              Humm, Quad Cam Goodness!!
              • Feb 2008
              • 136
              He said it had a 660 bell housing swapped onto already, are they different between the gen2 and the gen3?
                • 13522
                ah, i just saw GTZ. Ok, then thats all there is to it that I know of.
                • MY91GT(Z)
                  • Sep 2006
                  • 387
                  he never gets back to any1 when they really show interest and not to mention if u check up on this guy from v6z24.com he is banned for takin ppl for their money too
                  • Z26-T
                    • Apr 2008
                    • 486
                    Not a bad deal on the heads...
                    Did you port them yourself?
                    "he never gets back to any1 when they really show interest and not to mention if u check up on this guy from v6z24.com he is banned for takin ppl for their money too"
                    But that kinda scares me...
                    • MidnightriderZ24
                      • Jan 2005
                      • 699
                      and if u check up on me on this site i havent had one problem. ever. as for banned i wasnt banned, i stopped posting due to being labeled for no reason. besides i really wasnt in any place to sell the trans to you at that time since i had no way of shipping a trans that was in wisconsin when i was in college in chicago. i really would like to have a pick up or meet somewhere for the trans. but yes, its a 90 quad four trans with the v6 bellhousing already swapped over. i ported the heads with carbide bits and sanding cartridges. i can snap more pictures of the porting as soon as i can find my sd card for my camera..
                      [SIGPIC]
                      • MY91GT(Z)
                        • Sep 2006
                        • 387
                        well i was informed by some1 from v6z24 site bout u and read up on it, which didnt seem so promising which is another reason y i stopped tryin to contact u bout it
                        • MidnightriderZ24
                          • Jan 2005
                          • 699
                          bump, 170 shipped for heads. 300 for the trans.
                          [SIGPIC]
                          • MidnightriderZ24
                            • Jan 2005
                            • 699
                            bump. heads sold. trans is still up!
                            [SIGPIC]
                            • kwhauck
                              Olds Sleeper
                              • Aug 2006
                              • 379
                              very tempting on the trans to have a back up........damn.....
