1.6 rockers
  • 1988GTU
    LB62LHObbqftmfw
    • Nov 2005
    • 2475
    For Sale : 1.6 rockers
    I have a set of 1.6 stamped rockers forsale. You might ask, "Why would I want those?" .
    If you have a 2.8 or 3.1 mpfi and your engine has the stock rockers, you'll find that the rockers in there now are 1.5 ratio.
    What these 1.6 rockers are made to do, is to mimic as if you installed a slightly more aggressive cam. What's great is that you will not have to pull the engine, heads and all that jazz to install these.
    If you can replace valve cover gaskets, you can install these.
    You reuse your pushrods, studs, guides, bearings and nuts. Just replace the old 1.5 rockers with these 1.6's!
    No tune is required, no extra fuel is needed, and it's an easy modification!
    50.00 SHIPPED anywhere in the USA ( OBO )
    Will ship to canada, PM for shipping quote.
  • LeftVentricle
    Right aorta
    • Oct 2005
    • 507
    Didn't you say the guides or something had to be modified?
    • 1988GTU
      LB62LHObbqftmfw
      • Nov 2005
      • 2475
      This is how I went about it.
      I have a few 2.8's and 3.1's....
      Not ALL of them I did the guide grinding or guide swap. I just left them as they were. This was for the DD car.
      Now for the other cars I DID take out the old ones and grind the guides ABOUT 1/16".
      All cars run flawlessly.
      I guess to ensure proper fitment, you should "grind the guides" .
      Another thing to note is, this mod is cheaper and safer than a Under Drive Pulley. Easier AND CHEAPER than putting headers on, and still cheaper than a TRUE cold air intake in most cases.
      • LeftVentricle
        Right aorta
        • Oct 2005
        • 507
        If grinding is not necessary, I'll take them.
        • 1988GTU
          LB62LHObbqftmfw
          • Nov 2005
          • 2475
          I am not going to suggest NOT to grind them. It's not hard to do. Another interesting thing to note is that the roller tips that I have came with instructions and all that to install, but no where on them can I remember it saying modifying the guides... Food for thought.
          PM me if you want to buy them and we'll exchange info.
            • 13531
            They probably didn't have a problem for the iron head motors that they were designed for.
            • Rhedalert
              Dr. Feelgood
              • 1574
              I installed these on a 3.1 MPFI years ago and had no guide to pushrod clearance issue. You SHOULD be good to go, it's well worth the investment.
              Brian
              3400 SFI V6, 4T60e
              • 1988GTU
                LB62LHObbqftmfw
                • Nov 2005
                • 2475
                Exactly!
                TTT!
                  I wonder if 3x00 roller fulcrums would work too if you machined off the tab on the bottom of them....
                  • 1988GTU
                    LB62LHObbqftmfw
                    • Nov 2005
                    • 2475
                    I dont know, but I do know these 1.6 stamped rockers are simple mod. Easy HP for a cheap price.
                      I would guess they would work, since the 3x00 heads with notches can swap to the rollers if the year doesn't have them already. So for non-notched heads (like mine) I would keep the guides and mod the rockers... Hmmmm. (thinking out loud)...
                      free bump :P
                      • 1988GTU
                        LB62LHObbqftmfw
                        • Nov 2005
                        • 2475
                        Haha thanks!
                        C'mon folks, sold a set still have another!
                        • 1988GTU
                          LB62LHObbqftmfw
                          • Nov 2005
                          • 2475
                          ttt.
                          • 1988GTU
                            LB62LHObbqftmfw
                            • Nov 2005
                            • 2475
                            • 1988GTU
                              LB62LHObbqftmfw
                              • Nov 2005
                              • 2475
                              Hey hey hey!!!!
