Lots of Engine 3X00 parts
  • 92cavquest
    • Feb 2008
    • 150
    #31
    Cavalier
    95-99 cavalier brake calipers w/ hardware and semi-metallic pads $20
    95-05 cavalier 4t40e trans mount $10
    95-99 cavalier 3 speed trans mount $10
    95-99 cavalier 2.2 ohv front motor mount $10
    95-02 cavalier radiator cover $5
    95-99 cavalier gauge cluster w/o tach $10
    95-99 cavalier 3 speed shifter assembly $10
    Steelies with new rubber $90
    Grand Am
    4t45e side cover $10
    Alero alloy wheel $10
    (3) 18" Forte Black Russ Wheels 5x100 and 5x114.3 MAKE OFFER
    3400
    3400 front timing cover w/ water pump $15
    3400 oil pan $25
    .10 over crank bearings $25
    3400 exh. manifold covers ceramic coated in silver
    timing cover gasket set TCS45828 $5
    oil pan gasket set OS20668R $12
    3500
    3500 upper intake $70
    36# GTP injectors w/ pigtails $75
    3500 fuel injectors w/ harness $30
    3500 fuel rail $25
    3500 exhaust manifolds w/cats $40
    WOT-TECH stage 3 turbo cam 1617 grind $200
    custom pushrods for the cam above $70
    misc. other 3500 junk (let me know what you need)
    Misc.
    Holset hx35g turbo $120
    4 used 4 wire 02 sensors $10 each
    3" diameter x 6" length silicone couplers $4 each
    bolt or weld on 4" chrome exhaust tip $10
    • ghrarhg
      • May 2005
      • 215
      #32
      Interested in the hx35g. PM me shipping cost to 44060.
      • 92cavquest
        • Feb 2008
        • 150
        #33
        Cavalier
        95-99 cavalier brake calipers w/ hardware and semi-metallic pads $15
        Grand Am
        (3) 18" Forte Black Russ Wheels 5x100 and 5x114.3 Cavalier and Grand Am w/tires MAKE OFFER
        3400
        3400 oil pan $20
        3400 exh. manifold covers ceramic coated in silver $15
        3500
        3500 fuel rail $25
        Misc.
        6 used 4 wire 02 sensors $10 each
        • 92cavquest
          • Feb 2008
          • 150
          #34
          Turbo and 350 intake are on ebay.http://cgi.ebay.com/ebaymotors/Holse...item35a772a4da
          http://cgi.ebay.com/ebaymotors/2005-...item35a772c825
          • ghrarhg
            • May 2005
            • 215
            #35
            Seriously? I offered to pay you your asking price for the turbo + shipping. You said that you had offers for more so you wouldn't sell it to me. Now you have it on Ebay? On top of that you post it HERE! Don't offer to sell something for a given price and then renege on it. That's just bad business. I can understand why other people have flamed you for it on other forums.
            • 92cavquest
              • Feb 2008
              • 150
              #36
              I have posted the turbo on ebay to give the 3 parties interested in it a chance to fiqure out which one wants it the most. We all got together in emails and that was the most logical thing to do. There's only one person on another site flaming me and he was a low baller that got mad I would accept more than $100 for something I was asking $120 for.
              Sorry if I made you angry. If you really want it then bid on it.
              • 92cavquest
                • Feb 2008
                • 150
                #37
                Cavalier
                95-99 cavalier brake calipers w/ hardware and semi-metallic pads $10
                95-99 cavalier gauge cluster w/o tach $5
                Grand Am
                (3) 18" Forte Black Russ Wheels 5x100 and 5x114.3 Cavalier and Grand Am w/tires ALMOST FREE MAKE AN OFFER
                3400
                3400 oil pan $15
                .10 over connecting rod bearings $20
                3500
                3500 upper intake $50
                3500 fuel injectors w/ harness $20
                3500 fuel rail $15
                3500 exhaust manifolds $8
                Misc.
                6 used 4 wire 02 sensors $6 each
                3" diameter x 6" length silicone couplers $3 each
                • gar70614
                  • Oct 2008
                  • 330
                  #38
                  do u have the grand am timing cover motor mount? i need the peice that bolts 2 the cover and the part that goes over to the rubber mount?
                  • 92cavquest
                    • Feb 2008
                    • 150
                    #39
                    I'll look around for the one I have. If I can't find it I will go to the yard and get you one.
                    • gar70614
                      • Oct 2008
                      • 330
                      #40
                      if u have one ide be interested but ill just head to my local yard if not. thanx tho
                      • flimbob
                        • Jan 2010
                        • 73
                        #41
                        Do you still have the 3400 timing cover/waterpump and the timing cover gasket set? If so, I'd like to arrange to come and get them. I'm located in Plano. Where abouts are you located in Fort Worth?
                        • 92cavquest
                          • Feb 2008
                          • 150
                          #42
                          I do still have them. That would be fine. Shoot me a PM.
                          • 92cavquest
                            • Feb 2008
                            • 150
                            #43
                            Make an offer guys. Getting ready to throw all this stuff out and would like it to go to a good home.
                            Cavalier
                            95-99 cavalier brake calipers w/ hardware and semi-metallic pads $5
                            95-05 cavalier 4t40e trans mount $5
                            95-99 cavalier 3 speed trans mount $5
                            95-99 cavalier 2.2 ohv front motor mount $5
                            Grand Am
                            (3) 18" Forte Black Russ Wheels 5x100 and 5x114.3 Cavalier and Grand Am w/tires ALMOST FREE!!! $50
                            3400
                            3400 oil pan $15
                            3500
                            3500 fuel rail $15
                            WOT-TECH stage 3 turbo cam 1617 grind $180
                            Misc.
                            3" diameter x 6" length silicone couplers $2 each
                            • 92cavquest
                              • Feb 2008
                              • 150
                              #44
                              Cavalier
                              Grand Am
                              3400
                              3400 oil pan $15
                              3500
                              Misc.
                                I would like to add I believe that timing cover gasket set listed under the 3400 will fit any 60v6, IIRC.
