Lots of Engine 3X00 parts
  • Rootie524
    • Feb 2010
    • 543
    #46
    are those 02 sensors the down stream ones? (after cat?)
    the timing cover w/ water pump. is the pump new or used?
    can the 3500 cam be used in a 3400 block and does it have a spec sheet? it says turbo cam so im assuming its for turbo applications?
    Depending on the answers to those questions..how much for the timing cover (probably w/o pump), one o2 sensor, the 3400 oil pan (w/ gakset), and the .10 over rod bearings all shipped to 18062
      A 3500 can cam be used in a 3400. I replaced a cam in a Pontiac minivan (3400) with a 3500 cam. The cam position sensor ring looks different, but the PCM reads it just fine.
      • Rootie524
        • Feb 2010
        • 543
        #48
        what/where exactly is the CPS ring?
        • 92cavquest
          • Feb 2008
          • 150
          #49
          I have 2 pre cat and 2 post cat 02 sensors. The timing cover has a used water pump mounted to it but I have a brand new one sitting in a box if you want it. The cam can easily be used in a 3400 block. It's from the store on here. Used to be the stage 3 turbo cam.
          The specs are:
          274.1/273.5 Adv Duration
          220.3/215.3 .050 Duration
          .502/.496 with 1.6:1 rockers
          113 ICL 114 LSA
          I'll do the cover, new water pump, 02 sensor, oil pan and gasket and connecting rod bearings for $75 shipped.
          I'd really like to sell the cam and pushrods though. I'm taking a big hit on them as they've never been installed.
          • Rootie524
            • Feb 2010
            • 543
            #50
            i could do $70 shipped (i like even numbers lol) you'll have to wait a few days till i get the money though.
            is that cam streetable? and if its pretty streetable id be interested in it at a later date when i get even more spending cash. and it may be a turbo cam but does it require boost to run well?
            • 92cavquest
              • Feb 2008
              • 150
              #51
              I guess I can do $70. The cam will work okay in a n/a car but will really scream in a turbo car. Mybe others will chime in and let us know how well it'll work.
                Right below the CPS sensor, or about 1 1/2-2" back from the timing chain gear.
                • 92cavquest
                  • Feb 2008
                  • 150
                  #53
                  Still interested?
                  • 92cavquest
                    • Feb 2008
                    • 150
                    #54
                    3400 .10 over rod bearings $20
                    3400 oil pan $15
                    3400 timing cover $15
                    3400 timing cover gasket set $10
                    3400 brand new water pump $5
                    3400 valve covers w/ gasket $20
                    3500
                    3500 upper intake $80
                    36# GTP injectors $90
                    3500 exhaust manifolds $20
                    WOT-TECH stage 3 turbo cam 1617 grind $200
                    custom pushrods for the cam above $70
                    Misc.
                    Holset hx35g turbo for parts only -broken shaft $50
                    2 used 4 wire 02 sensors $10 each
                    10 3" diameter x 6" length silicone hump hoses $4 each
                    10 3" diameter x 3" length silicone hump hoses $4 each
                    10 3" p-clips $1 each
                    1 3" s bend $10
                    4 2.5" 90 degree to 3" cast elbows $7 each
                    10 3" aluminized steel 45 degree bends $7 each
                    1 3.5" to 3" reducer $5 each
                    5 2.5" blue silicone couplers $2 each
                    4 AN-6 3ft hoses (trim to make shorter) $10 each
                    2.4 Cavalierdrop in k&n air filter $10
                    JVC KD-S590 cd player $20
                    Pics can be seen HERE
                    • Rootie524
                      • Feb 2010
                      • 543
                      #55
                      i've decided im going to turbo my car now instead of going NA. so interested in the cam and push rods..
                      is it this cam: http://wot-tech.com/shop/all/race-tu.../prod_275.html
                      or this oneL http://wot-tech.com/shop/all/street/.../prod_274.html
                      • 92cavquest
                        • Feb 2008
                        • 150
                        #56
                        3500
                        36# GTP injectors $100
                        Misc.
