3400 head cores
  • 2.8/3400 1985 Camaro
    • Nov 2009
    • 192
    Wanted 3400 head cores
    Just the heads, no valvetrain, looking for good condition, P&P a plus but not necessary, looking to pay ~$100 for a decent set, maybe more if they're P&Ped.
    http://www.cardomain.com/ride/390342...evrolet-camaro
  • mfuller
    Mr. Common Sense
    • Nov 2003
    • 374
    I have a set of 3400 heads (they are assembled with valves, springs and whatnot), but I wouldn't trust 'em without disassembly and a good cleaning and replacing the valve seals). Where are you located?
    Matt
      • Nov 2009
      • 192
      I just want the heads....
      Non assembled, ie. no valves, no valve springs, no pushrods, no rocker arms, no lifters, no seals or seats.....I don't want to pay for stuff I'm not going to use, the setup I'm going to be running requires high end components to match the cam I'm getting, the stock valvetrain just won't take the abuse the cam will throw at it, especially not at 7k rpm, not to mention valve float....
      • asylummotorsports
        Banned
        • Oct 2005
        • 649
        Not to be a PITA but evidently I'm good at that.
        Ben stopped selling ported 3400 heads for the most part, for a reason!
        Too bad with a 2.8 you are stuck with bore restrictions.
        FWIW!
          • Nov 2009
          • 192
          And now they are all on sale 'cause nobody wants them!
          STOCK 3500 heads flow better and make more power. As issued!
          FWIW!
          To the best of my knowledge my 2.8 block won't take 3500 heads......
            • 13525
            To the best of my knowledge I still sell ported 3400 heads.
              • Nov 2009
              • 192
              How much are they per set? And how much of a flow increase is the porting on them?
                Live life 3.7mi at a time
                • 4555
                GM 2.8, 3.1, 3.4, 3.5, 3.9 V6 Engine Performance Parts and Services
                Ben lists all the stock and ported flow #'s
                I have a set of unmolested 3400 heads, bare, one rocker arm stud boss (10mm) needs a heli-coil - but don't know if I want to get rid of them, or use them for some flow testing...
                • geldartb
                  The Situation
                  • May 2004
                  • 1994
                  where are you located.
                  i still got my 3400 heads in the garage.
                  99 Grand Am GT
                  1357 cam 227 233 .050 dur
                  515 515 lift 112 lsa
                    • Nov 2009
                    • 192
                    Pittsburgh, PA, do you have a picture so I can see the condition? And how much do you want for them?
                    • MY91GT(Z)
                      • Sep 2006
                      • 387
                      i have set also ill sell for 100 shipped complete minus the rockers
