Or Trade! Full Roller Rockers 1.6:1 ProComp
  • blownarrow
    FWD isn't that cute?
    • Oct 2008
    • 160
    For Sale : Or Trade! Full Roller Rockers 1.6:1 ProComp
    ProComp Blue 1.6:1 Full Roller Rockers For sale or trade!
    I don't have a price in my head so hit me up...
    Looking for after market roller tip /or full roller for an Iron Head
    Or Nice mild P&P iron heads for trade...
    sigpicWhen I die, I want to go peacefully like my Grandfather did, in his sleep -- not screaming, like the passengers in his car.
  • eckoxl
    • Jul 2009
    • 230
    Will these work on 3x00? and how much?
    1999 Grand Am SC/T - 301HP, 365TQ - ARP Rod Bolts, ARP Oil Pan Bolts, ARP Head Studs, Mild Cam, 3500 Heads w/28696 Springs, Ported 3500 LIM & 3400 UIM, GT32R @ 12PSI, Rebuilt Trans, 42.5 Injectors, Racetronix Fuel Pump, TCE Adjustable FPR, SC/T Kit, SC/T Spoiler, Shaved Trunk, WOT-Tech Coil Overs, Solid Rear Laterals w/Poly Bushings, Control Arms w/Poly Bushings, Poly Engine & Trans Mounts, Front & Rear Strut Braces
    • blownarrow
      • Oct 2008
      • 160
      They should, there the same as these just BLUE
      I'm thinking 175+shipping????
        Live life 3.7mi at a time
        • 4555
        Sill man! Those WILL work on the iron heads. You just need the 10mm to 3/8's adapting studs (if there is slop with those rockers on the 10mm studs anyways).
        -John
        • blownarrow
          • Oct 2008
          • 160
          Really? with out machining? I was under the impression that they don't have enough clearance at the rear of the lifter on an iron head..
          • blownarrow
            • Oct 2008
            • 160
            Thats a negitive ghost rider the pattern is full!
            These "Will Not Work On Iron Heads With out Alot of machining"
            I figured I would check first so I went to work and made a set of mock-up
            3/8 X 10mm studs and nope! So the offer to Sell/Trade is still open!
            and yes they will work on 3x00 alum heads
            Silly man....
              • 4555
              Those are really wide!
                Unfortunately the only benefit of using these on a 3x00 motor is the roller tip... since the stockers are already 1.6 ratio.
                • 1988GTU
                  LB62LHObbqftmfw
                  • Nov 2005
                  • 2475
                  I am kinda of interested, but I was looking at these for 155.99 and they are new.
                  How adjustable are you with your price?
                  • blownarrow
                    • Oct 2008
                    • 160
                    Very ajustable... pm sent!
                    • blownarrow
                      • Oct 2008
                      • 160
                      Bump! Sell or trade!
                      • scott0999
                        • Aug 2006
                        • 180
                        man those rockers are all over the place. the top ones on the left look like their hitting each other. hardly any of them are centered
                        '94 Cavalier Z24 3400 Turbo 5 spd
                          • 13522
                          No pushrods. That looks likeFranz's setup with gen 2 heads.
                          • scott0999
                            • Aug 2006
                            • 180
                            ah yes that would help lol
                              I thought gen2 heads didn't have even spaced intake ports? Looks like 3x00 heads to me... Looks like double roller chain on the block, so gen1 or gen2 block though.
