60*V6 flywheel/clutch bolts
  • gpchris
    • Feb 2007
    • 477
    Wanted 60*V6 flywheel/clutch bolts
    I'm looking for the 6 bolts that bolt the flywheel to the crankshaft AND the 6 bolts that bolt the pressure plate to the flywheel. Need these asap! Tia
  • 60dgrzbelow0
    "Yes... I AM IRONMAN..."
    • Mar 2009
    • 1344
    Try calling either of these folks...they should have what you need...
    HeadBolts cylinder head bolts and engine fasteners - cylinder head bolts / studs and related automotive fasteners for domestic and import engines. OEM style and performance ARP brand fasteners
    http://www.jegs.com/p/ARP/ARP-Flywhe...8-38db0de2603c
    • MidnightriderZ24
      • Jan 2005
      • 699
      pressure plate bolts just go to a parts store and pick some up. metric 10.9's will be perfect. flywheel bolts are gonna be tough to get.
      [SIGPIC]
      12.268@117... 11's to come!
      • 3400beretta
        Banned
        • Jul 2005
        • 171
        Go to the dealer.
        • RedBird
          Aka Mr. 5th Motor
          • Sep 2006
          • 426
          uh...
          Cammed 3400 --> 224whp 210wtq
          Cammed 3500 --> ???
          1 of 5 3500 J-Bodies
          • MidnightriderZ24
            • Jan 2005
            • 699
            yeah the title says flywheel bolts, but the item description says flexplate.. HUGE difference as we know... maybe ben can clear this.
            [SIGPIC]
              • 13522
              Same bolt.
              • MidnightriderZ24
                • Jan 2005
                • 699
                flexplate bolts are alot shorter than 5 speed flywheel bolts. if the bolts in the store are the longer flywheel bolts, i would LOVE to get some!
                [SIGPIC]
                  • 13522
                  Im sure you have seen more flexplate and flywheel bolts than anyone on this site.
                  • MidnightriderZ24
                    • Jan 2005
                    • 699
                    ok, taking what i say out of context to apply to this doesnt mean anything. i was simply stating the title of the item says flywheel bolts, then the item description says flexplate. when clearly flywheel bolts are LONGER. there has been a few people who ran the shorter flexplate bolts and had issues on a flywheel. im trying to figure out which bolts they are?
                    [SIGPIC]
                      • 13522
                      They work with both.
                      • MidnightriderZ24
                        • Jan 2005
                        • 699
                        im just curious cuz ive wanted to buy them, but wasnt sure if they were either, or. if they work with both then thats great, another worthwhile upgrade for sure.
                        [SIGPIC]
                        • RedBird
                          Aka Mr. 5th Motor
                          • Sep 2006
                          • 426
                          phew. had me worried for a second.... since i used these on my flywheel :P i need to get the pan side bolts, too.
                          Hey Ben, maybe you should change the description to say flywheel and add a note at the bottom that says will also work with automatic flexplates
                          Cammed 3500 --> ???
                          • gpchris
                            • Feb 2007
                            • 477
                            The flywheel bolts ARE different than the flexplate bolts. Just putting that out there. I would bet my life on it.
                            Thanks to whoever said I can get a universal 10.9. I'll hit fastenal tomorrow. Even if I have to pay 4 dollars per bolt at the stealership atleast I'll only need the six flywheel bolts.
                              Flywheel bolts are 11.9 grade IIRC. Fine thread but no idea what it is. 10.9 for pressure plate and are coarser thread compared to flywheel ones.
