1992 Grand Prix, 1994 Cutlass, 1991 Grand Prix
    • 13522
    you can probably swap them out at the house. Especially if Jon goes Yes it was hit in the front in a parking lot and the driver side headlamp bracket is tweaked. I have another set I believe but I don't know if they are in the car, under the hood, or in the shed. The hood is now white and has some rust underneath it. There might be a strut tower brace. I know the trunk has a bunch of parts I need. There are hubcaps for a 59 olds in there still I think plus drivetrain pieces I want to keep.
      i still have my tools around from when i did a thorough cleaning of the 90(everything from the carpet and upwards was pulled), so the way i was thinking was to get over to elkhart, remove the current seats, store them in the back of my father's tahoe, transport them down to warsaw, swap them, come back up to elkhart, bolt in the red seats, then trailer it? seems to make the most sense to me.
      between the 90GP and MC, i have two functioning braces that i welded together in the summer of 08 out of 1 1/2" tubing. i certainly wouldn't need another.
      i assume Jon will have a list of everything that needs to be pulled?
        • 13522
        both cars are in warsaw, so you can swap the seats out of the 92 and the 91 right there. The grey seats in the 91 are barely in there. The 92 will need the seats removed, the arm rest needs to lift up a little for the switches and wiring. The wiring just goes between the seats so that isn't much.
          ahh, that simplifies things quite a bit then.
          by arm rest, you're referring to the center console? it took maybe 10 minutes to pull the entire assembly when i cleaned out the 90 and found all of the screws/bolts. sounds like just a connector or two would need to be disconnected inside of it, then one end lifted while the harness slides out?
            • 13522
            Yup, the inside tray comes out, then a few more bolts and lift the back up. The controller goes right where the change tray is next to the latch for the glove box Then you have the air line to the passenger seat. It might take an hour total.
              air line? lumbar pump?
              i got pretty good about removing seats/etc when i installed my relatively hidden amp in the MC, only had to pull/install the seats about 3 times in one night.
                • 13522
                #22
                yup its the 5 way cutlass seats so it does all kinds of stuff for a 1991 no dic or heads up.
                  DIC feels kind of gimmicky after watching them for a while, though i'll be integrating a HUD eventually. are the provisions there for either of them already?
                    • 13522
                    #24
                    nope, there is nothing there for either.
                    • 95SleeperAcheiva
                      ArtofOlivia"PocketRocket"
                      • Jun 2006
                      • 694
                      #25
                      no not pics of the GP, the cutlass! :P
                      Today I went to install the motor my dad and I were playin with. I jacked the car up on the K-member to bolt down the engine mount and I got to watch the K-member push right through the body shell. I propmtly removed the engine and trans, and went and got drunk.
                      So...yes I am VERY interested in the cutlass and could you be a dear and look around for a 1986-1990 Oldsmobile 88, 98, or toronado with a sweet body and no motor or trans? One from your area, preferabley reeealy cheap. Then I can come down, buy the cutlass, buy the nice body you find, drive them back and install the 26k mile motor and trans I now have sitting under my picker into it?
                      THanks, ANOTHER BEER!!!!
                        all of which were 3800 cars?
                        my father in law is potentially interested in the CS, should your deal fall through.
                          • 13522
                          #27
                          The cutlass is in indiana. Its a $500 car, with leather seats, 5 spoke rims, rebuilt trans, sony cd deck, dirty carpet, mostly good exterior, and new axles, front hubs, and shocks/struts as of a few years ago. It also has the rear and front STB. Im giving it away for 500. its worth more as a parts car for the 95 convertible that we have but I don't need it for anything other than parts.
                          • 95SleeperAcheiva
                            • Jun 2006
                            • 694
                            #28
                            even better it's closer! cam carrier leak means it's a DOHC, i'm foggy atm forgive me. I gotta sell my dad on it, pics would help.
                              I looked and looked for pics from the 2005 60v6 meet and didn't see any at all on here... If you watch the vid of the Minus One that Josh posted, you should be able to see it parked. It was the only red and black Cutty at the meet (and the only Cutty at the meet, IIRC).
                                • 9189
                                #30
                                Pics of the red and black Cutlass can be found here: http://60degreev6.com/forum/gallery/...=3&userid=6152
