$325 shipped (lower 48 ), new set of 24 springs (26113) with the retainers to go with them, and a set of spring seats modified to fit around the stock valve stem seal. Thats basically free retainers and the seats to someone that has a 3.4 DOHC and wants some awesome springs. Stiffer than stock, and coil bind is tighter so you could run a regrind if you want.
Comp springs for 3.4 DOHC with retainers and seats
For Sale : Comp springs for 3.4 DOHC with retainers and seats
Tags: None
http://www.jegs.com/i/COMP+Cams/249/26113-16/10002/-1
.952" coil bind and 1.400" install height so .400 lift is no problem. If you go more than that, I would have the spring seats cut down to keep the springs happy.Ben
Bump. Retainers are 792-16, but 24 of them. They are only sold in 16s or individually.Ben
