aluminum bow tie block
  • Guest
    Brand new $1100 shipped. I might be able to send in original GMPP crate.
  • Darin
    • May 2006
    • 259
    LOL, What block? LS1? A little more info would be a lot of help.
    1999 Grand Prix SE 3100
    1997 Dodge Ram 1500 4X4 Ext cab. 5.2L
    1977 Dodge Power Wagon, Short bed, Fuel injected 360, 4spd, Dana 60's, Little Red Express bed.
      • 13531
      60DegreeV6.com regards the bowtie block as the 60V6 bowtie block for these motors. Shaun has a lot of rare 60V6 parts. If it was LS1 or whatever, he would say that for sure. So yeah, I am confident in telling you what he has:P
      • Darin
        • May 2006
        • 259
        I figured, Its just nice when people post exactly what they have for sale sale.
        Its like me posting I have a set of wheels for sale. $1100
        • gectek
          Banned
          • Aug 2006
          • 1472
          what year and what all is included? and which 60* is it?
          • boostedrs
            • Mar 2006
            • 168
            dam intersted,
            what bore size or does it have unfinished bores?
            crank main journal size?
            does it have the mounting bosses for use in a rwd aplication?
            any pics?
            • FieroNelson
              Modification Addict
              • Dec 2006
              • 44
              I'll take two.
              • Guest
                10051141 — Bow Tie Aluminum Block
                This heavy-duty aluminum block is 47 pounds lighter than a production rear-
                wheel-drive cast iron block. It has extra-thick cylinder walls with dry nodular
                iron sleeves. The head bolt bosses are reinforced to improve head gasket
                sealing. This block has wider main bearing bulkheads than a production
                cylinder case; four-bolt caps are installed on the two intermediate main
                bearings. These billet steel main caps have splayed outer bolts that provide
                additional bearing support.
                The aluminum Bow Tie V6/60° block features a revised lubrication system.
                The “priority main feed” oiling is similar to a Chevrolet small-block V8, with
                three oil galleries above the camshaft; production V6/60° blocks have only
                two oil galleries. Oil is routed directly to the main bearings in a Bow Tie
                block to ensure proper lubrication at high rpm. The main bearing saddles
                are grooved to increase the flow of oil to the crankshaft journals through
                additional feed holes drilled in the upper bearing inserts. Block weight is 59
                lbs.
                Technical Notes: Aluminum Bow Tie V6/60° engine blocks have rough-bored
                89mm (3.504") cylinders which can be safely overbored to 91mm (3.582").
                Light alloy Bow Tie blocks have bosses for both front-wheel-drive and rear-
                wheel-drive engine mounts. The starter motor can be installed on either side
                of the block
                • Nightingale
                  • Apr 2005
                  • 259
                  its times like this that are seriously screw with my head... Bowtie block or 3.9L v6? AHHHH!!!
                  98 camaro swapping in lz9 th400 setup
                  LZ9 specs: (Subject to Change work in progress)
                  4.0L(after bore 3.917 and stroke 3.3485),carrillo sbc rods(narrowed),wiseco custom forged pistons 8.5:1 CR, TCE Double Roller timing chain, gen 3 cam, P&P heads, headers 1 3/4 primaries into 3-1 collector, and going to run ms2.
                  • ProjectMM
                    • Mar 2004
                    • 170
                    I'm just wondering if the block comes woth a cam and crank, or just a bear block?
                    2002 Pontiac GrandAm GT1
                    3400 v6
                    TOG headers
                    RSM 62MM T-body
                    FFP underdrive pulley
                    GRANATELLI MAF
                    Ported upper intake
                    MSD DIS 4 ignition box
                    MSD Wires and coils (pending)
                    Venom high flow fuel pump (pending)
                      • 9191
                      It'd be just the bare block.
                      • Guest
                        sold thanks
