wtb (pic inside)
  • 1988GTU
    LB62LHObbqftmfw
    • Nov 2005
    • 2475
    About how much would I be looking at if I were to have Geoff fab that up? Thanks.
    • geoffinbc
      Iron Head Enthusiast
      • 5831
      What is its size about 6" X 10" or so? I need to know how much material. But for a one off piece I will estimate about $50CDN plus shipping which might be around $15 to $20
        • 9190
        Its probably closerto 4"x7" probably. I need to get the file from work and so I can mess with it some more on something other than my lunch break.
        • 1988GTU
          LB62LHObbqftmfw
          • Nov 2005
          • 2475
          Ok I concluded this is what I would want to do.
          Unless someone sees something I dont, it looks like a solid plan. ??
          the turbo side
            • 9190
            Ok, so it that latest picture the actual piece I am trying to mate up to? If so, then I can just edit the drawing to match that...
            • 1988GTU
              LB62LHObbqftmfw
              • Nov 2005
              • 2475
              #21
              Correct. That is what I am trying to match up to. Keep in mind that I have to attach an exhaust to it so it has to remain that same oval dia or the flange needs to be deep enough to clear the wastegate and have a round 3" opening to weld to.
                • 9190
                #22
                Updated...
                • 1988GTU
                  LB62LHObbqftmfw
                  • Nov 2005
                  • 2475
                  #23
                  For some reason those two look kind of questionable...
                  Maybe this
                  Little more material? I would rather have it over lap some.
                  Thanks for the help Brad.
                    • 9190
                    #24
                    Ok, I decided to take your route... And I overlaid it onto the last pic you provided so you can see how it will overlap the turbo.
                    I love AutoCAD!
                    • 1988GTU
                      LB62LHObbqftmfw
                      • Nov 2005
                      • 2475
                      #25
                      That looks 110% Brad! THANK YOU! I'll ask a buddy of mine to print that pdf and I'll lay it over the Turbo.
                      Thank you again!
