3500 lifters to fit 3100 or 3400 engines on ebay!
  • farmerz24
    • Feb 2004
    • 361
    take a look
    http://cgi.ebay.com/ebaymotors/ws/eB...2510561&rd=1,1
    • 13531
    Yeah? Did you not know the lifters were the same or are you excited about used lifters?
      Live life 3.7mi at a time
      • 4555
      Sappy, will they fit a LHO (RWD 3.1, 1990)? Someone on another site is trying to retro-fit a roller cam on an F-body (haven't heard lately).
        • 13531
        I don't know for sure so I won't even guess. I don't have a flat tappet setup here to check. I know curtis went roller but that was solid so they aren't the same lifter.
          • 4555
          I'll get back when I hear something then...
          • IsaacHayes
            Mr. Orange.
            • Apr 2006
            • 6030
            Ben, you think 200,000 mile 3100 could benefit from these lower mileage lifters? My car runs real good, but always looking for cheap refreshers.
              • 13531
              If your car runs good, your lifters are probably fine. However, 200k is quite a few miles. Price is right but you gotta tear the engine down to swap them. I don't know that I would do that right now.
              • IsaacHayes
                Mr. Orange.
                • Apr 2006
                • 6030
                Do the heads have to come off to get the lifters out? I just thought about that. I still gotta swap my intake manifolds, but I'm not touching the heads..
                • gectek
                  Banned
                  • Aug 2006
                  • 1472
                  no, for lifters just the uim, lim, and valve covers and rocker arms/push rods. then the lifter plate and they will pull right out
                  • IsaacHayes
                    Mr. Orange.
                    • Apr 2006
                    • 6030
                    Thanks guys!
                    • farmerz24
                      • Feb 2004
                      • 361
                      i know that back in the day i did place a 3100 roller lifter into a flat tappet 2.8 block. so the bore size for the lifter is the same but it may end there.
                        • 9191
                        They will fit in a non-roller block, but they you need to figure out how to keep them in place, since the non-roller blocks don't have the provisions for the anti-rotation bars.
                          • 4555
                          Not only that, but there is a difference in the oil passages that if used on a non-roller cam motor, they would be starved for oil. A guy on TGO is looking for a way to use them in a f-body and I believe he has solved the rotation problem, but not the oiling.
                          • gectek
                            Banned
                            • Aug 2006
                            • 1472
                            cant you chamfer the bore with a bore chamfer kit, i thought i saw one from comp cams, that is what would give some needed lube
