W-body Trailing Arms W/poly
  • d.o.h.c
    • Jun 2004
    • 981
    I Have A Set Of Stock Trailing Arms That I Had Custom Made Poly Bushing Made For. They Cost Me Around $50 Just For The Bushings.
    I Will Shoot Up Some Pics Soon.
    $50 Shipped
  • dohcfiend
    King Chalupa
    • Jan 2004
    • 2351
    can your guy make stock front poly control arm bushings?
    if so lmk.
    • GPRacer
      • Mar 2005
      • 161
      if so lmk.
      word
      • d.o.h.c
        • Jun 2004
        • 981
        Yeah anythings possible with anough money. The poly is expensive and the maching is going to be some money. Probably around $200, but then it will be more things we can sell for the w-body
        • d.o.h.c
          • Jun 2004
          • 981
          If I can get like 10 people then I can get them made. I will start designing them.
          • dohcfiend
            King Chalupa
            • Jan 2004
            • 2351
            out of curiousity, how much would it be if i wanted a one-off set for myself?
            • d.o.h.c
              • Jun 2004
              • 981
              Well its about 100 for the poly and what ever for the machining
              • GPRacer
                • Mar 2005
                • 161
                damn...so how come you can buy the energy suspension bushings that are what, $30 for a set of two, including brackets? And they have just as much poly that would be required for the control arm bushings.
                  • 13467
                  ROFL! Cheaper to get them from RSM! HAHAHAHAHAHAHA
                    • 9175
                    Because energy suspension mass produces them, therefore the price will be much cheaper than just a single run.
                    • dohcfiend
                      King Chalupa
                      • Jan 2004
                      • 2351
                      i was thinking that too. $100+!?!. didn't get a whole estimate but for now based on some other numbers above i will say around $250-$300 would be a closer ballpark. it is high for my taste for the moment, but at least there is something available if i feel the urge.
                      but.... now that i have something to go off of for a comparison, i can perhaps talk to some larger companies and see what their estimates are vs d.o.h.c.'s estimate.
                      unfortunately, i have some other projects going on for the moment, so this will have to wait until something get's completed.
                      things usually do cost more for a 1st time R&D run. i know for certain that i could probably beat that price but the would the amount i save be worth my time spent finding it?
                      that leaves me with my last question for the moment. if i do pay for a single run for myself, do i get the cad files and stuff needed to cnc the bushings?
                      • CNCguy
                        Bisong eater :P
                        • Dec 2003
                        • 1017
                        Poly bushings are usually made in a molding process. The issue is, someone has to invest in having a mold made. Over time you have to recover the cost of the mold. The cost of poly bushings can be pretty cheap depending on the mold. The more cavities that a mold has, the cheaper the production costs are. I have some poly bushings made in a four cavity compression mold and my cost is $8 per bushing. The same part from a single cavity mold would probably cost around $20 each. A molding machine with a single cavity mold has to be cycled four times to get the same production as one with a four cavity mold. Of course, the price of the mold increases as you add more cavities.
                        Poly bushings also need to be greased regularly. Poly is a step up from rubber but materials like teflon impregnated nylon offer less flex. Nylon has its drawbacks as it requires a perfect axis of rotation or it will bind. Heim joints are the ultimate connection as they provide almost zero flex and can rotate easily on a misaligned axis.
                        Chassis Engineering by Herb Adams offers some good info on this and many other topics.
                        MinusOne - 3100 - 4T60E
                        '79 MGB - LZ9 - T5
                        http://www.tcemotorsports.com
                        • Juglenaut
                          • Dec 2003
                          • 1130
                          Can the right CNC machine cut poly?
                          I am back
                          Mechanical/Service Technican
                          • CNCguy
                            Bisong eater :P
                            • Dec 2003
                            • 1017
                            You can machine harder (80+ durometer) poly with extremely sharp cutting tools. Softer materials need to be frozen first using something like liquid nitrogen.
                            '79 MGB - LZ9 - T5
                            • dohcfiend
                              King Chalupa
                              • Jan 2004
                              • 2351
                              oh, it's molded? well damn.
