price question dohc topend
  • sil
    4T60-E killa
    • Nov 2004
    • 723
    hi, just wondering what anyone thinks or would pay for a used dohc topend setup, wbasicly everything but the block and tranny?
  • dohcfiend
    King Chalupa
    • Jan 2004
    • 2351
    RE: price question dohc topend
    what year?
    just guestimation
    91-95........200 plus shipping
    96.............250 plus shipping
    97.............325+ plus shipping
    basically, it all depends on timing. if you are looking when some1 is liquidating, you will get it much cheaper. if you are just fishing around expect to pay what is above.
    • sil
      4T60-E killa
      • Nov 2004
      • 723
      looks like a 96-97 cutlass
      anyway to distiquish what year motor by looks of the motor?
      • dohcfiend
        King Chalupa
        • Jan 2004
        • 2351
        mostly the intakes are the key.
        91-93 have a map sensor on the passenger back side of the plenum
        94-95 simply have a vacuum block there in the exact same spot and a mass air flow sensor is in the intake tube
        96-97 have a completely different plenum altogether but in that exact same spot you'd look for that sensor you will see the coilpacks.
        telling a 96 from a 97 is a whole different animal. if the whole assy is in the car or the tranny is attached, it is much easier. 96's have a 4t60e and 97's have a 4t65e. the difference is the 4t60e has a vacuum modulator and a 65 does not.
        if there is no tranny in there or a car it is in you really have to know the vacuum routing to tell. on the intake arm there is a connection for the modulator and on the 97 i believe there is not. hope this helps
        • sil
          4T60-E killa
          • Nov 2004
          • 723
          that helps, thank you
          i might go check it out tomorrow
          dont those things use the same block from 3x00 to dohc?
          i could do a dohc swap to my 2.8 block ?
            • 13514
            Nope, not gonna work. You gotta use the DOHC block (unless you are a fiero owner with a prototype aluminum block and think you know it all...then you can use your prototype block with the DOHC setup and run external oiling lines and such). The lifter bores in the pushrod block would have to be welded shut, oiling substantially redone, drainback holes made, weld the top of the block shut, etc. Get the whole motor if you want the DOHC engine.
            • donk_316
              • Mar 2004
              • 427
              LOL! and he would say "but its a prototype!!!!! with removable lifter valley!!! and 11 pounds lighter than....blah blah blah"
              1984 Indy Fiero 3.4L
              13.7 sec @ 98 mph
              *ALL THROTTLE AND NO BOTTLE*
